OK, here is the new version. The purple column shows the advertised EPA rated range. The yellow column shows the actual EPA test score. The green column shows what I think the advertised range should be if it was based on only the highway score instead of city and highway. EPA rated range is calculated 55% from city and 45% from highway range. That's because the test was designed to measure MPG for gas cars but they use the same test to measure EV range.
The advertised EPA rated range is not always the actual score because of voluntary reductions. Here is a screenshot from an EPA document that says "Combined range voluntarily lowered to 310 miles." It also shows the actual score which was 334 miles.
You can see that Tesla uses voluntary reductions a lot but usually for minor adjustments except for the Model 3. The interesting thing here is that the Model 3 P is expected to score exactly 310 miles EPA. Therefore there won't be any voluntary reductions for this model.
Data source for this screenshot: https://www.fueleconomy.gov/feg/epadata/17data.zip (Select the EV tab when you open the Excel file).
The full list of similar files can be found here: Download Fuel Economy Data
![AIgjHo1.gif](https://i.imgur.com/AIgjHo1.gif)
![xGzuk5i.gif](https://i.imgur.com/xGzuk5i.gif)
