I've been able to get it to 310-330 by shutting air conditioning and watching acceleration rate. Don't understand how folks are getting numbers in the 250-290 range.
I'll probably start an argument with this, but....Precooling and/or preheating helps a lot too. Driving on familiar roads where you know the terrain and traffic light patterns is also important.
Point of clarification:brianman I agree it is a form of cheating to use precooling/preheating to drive the Wh/mile down especially when the car is not plugged in, but that is Tesla's fault for calculating it that way. Getting into a precooled car is a luxury that I enjoy and is not something I endure to get better Wh/mi. On the other hand the question would remain if Tesla did count that energy in the Wh/mile would I still precool. I would certainly do it less than I do now and I would endure a hot car to some extent to get better Wh/mile results.
I kind of consider precooling / preheating "cheating the meter". If the trip meter(s) included the preheating/cooling costs (and then it was amortized over the trip duration in the UI) it would be a different story.
It's kind of like not making note of a significant decline in elevation (like driving down a mountain) when reporting "efficiency" for a leg of a trip.
Now I'm confused. When I precool my car, I come to it and by the end of the parking lot at work, I have 700+ to 1k+ Wh/mi. By the time I go a couple miles, I'm back down to the high 300s to then be in the low 300s about 10 miles later. I always figured this was the precooling showing up. Also, when I charge on the 120v at home, by the end of my driveway I am at 500 Wh/mo and get down to the low 300s by the time I leave the neighborhood. I always thought that is accounting for the BMS while I'm charging (on 120v, I never finish charging).
How are your vehicles not tracking that energy use when mine appears to be?
Ok, but this snippet is without being plugged in. It's when my car is sitting in the parking lot at work and I precool for about 10-15 minutes.What happens is that if you drive shortly after charging the Wh/mi is very high. I believe this is due to the cooling system running when you first start driving (leveling out the cells' temperature. It's most noticeable after Supercharging. If you let the car sit for a bit, it's not nearly as high. Preheating after charge completion reduces the starting Wh/mi number.
I understand the BMS may have needed to cool the battery, but this is NC, not AZ. I simply had thought it was taking into account the energy used to precool. I'll have to take more "measurements" and see how it goes.Now I'm confused. When I precool my car, I come to it and by the end of the parking lot at work, I have 700+ to 1k+ Wh/mi.
I've never precooled or preheated without being plugged in, so I don't have any data on what happens then.
