I say that because if you take 6.82 kWh (which I get from multiplying 16.2 x 421 from your first example) divided by 30 rated miles, that gives a reported rated efficiency of 227 Wh/mi, which is way too low. That means it is under reporting actual usage. At least in theory, while you are driving, all usage should be reported and computed into the driving efficiency. So somehow, your car (at least in that one case) was using extra energy that it wasn't accounting for. If included, this missing energy gave you a pretty ridiculous Wh/mi value (in the 500 range), although only reporting 421 Wh/mi, which is still pretty high.
