Where did you get that information from? Here is directly from their website:Any concern about the Ohmmu not having a BMS (compared to the MPP)?
Battery Management System prevents damage to battery in extreme situations and also balances the battery cells to maintain the pack for longer service life!>40Ah true Lithium capacity on 5hrs discharge test (more aggressive test than any Lead Acid test)Easy to carry handle and only 11lbs weight
Looks like I didn't read far enough...thanks for the feedback!
The difference in weight isn't noticeable in acceleration, cornering, efficiency, etc. even with careful measurement. Not to say it does nothing, just that it would have to be one of a long list of other expensive weight reductions.
They haven't been in use in Model 3 long enough to really tell if they last longer and meet all claims.
Could be a downgrade in cold weather as unlike an ICE vehicle, there's nothing nearby to warm it much.
IIRC they've sold about 60 of these ones specifically.
Under warranty? Pb.My 2017 3 showed the warning for my original 12v today. (Purchased Jan 2018.) Standard Pb, or Ohmmu /MP LiFePO4?
Under warranty? Pb.
70F for us CaliforniaWhat is considered cold? 32F? 40F?
If anyone has any insight![]()
As cheap as a new battery is, if I was at the two year mark and planning a road trip I would have no second thoughts and replace it with another OEM battery.Sorry if I’m late to the thread, but does it seem the 18-24 month battery life is more common in hot climates? I was wanting to avoid any major issue on a spring road-trip by preemptively replacing it as I approach the 2 yr mark, but I’m not in a hot climate and car is mainly garaged when not in motion. Thoughts?
That’s what I’m leaning toward with information I’ve acquired. I’ll talk with a Tesla tech next time I have the opportunity.As cheap as a new battery is, if I was at the two year mark and planning a road trip I would have no second thoughts and replace it with another OEM battery.
I asked them 3 times if they were OK with performing the depletion test. I then provided my email after they told me that was the preferred way to receive the results, and I provided my Tele # in case of any questions or problems.Did you follow up and see if the depletion test was conducted and what the stats/results were?
Have you had any issues lately with the MPP battery?Curious if my MPP lithium 12v is ever going to run into issues. I've had it nearly a year now and it's been great.
Why would the battery type here matter?Has anyone with a constant drain tried either the MPP or Ohmnu. I have a radar detector installed that stays on all the time cuz of sentry.
