jebinc
Downloading and installing 40.2 now (from 40.1.1), but I now see 40.2.1 rolling out per TeslaFi...
Edit: June 2019 build M3 LR AWD w/FSD
I do not have FSD and I got the warning once by not slowing for a stop sign. You really do have to be basically blowing through the stop sign for it to warn you.
Can you go test it out and share what speeds you get?
I am unbelievably dissatisfied with the 40.2 update, and I wish I could revert back to my last 36.x version. I get excessive weaving within my lane, NoA still makes poor decisions, the car seems to react to curves more poorly than ever before making entrance and exit a sharp, jerky motion, and sawing at the wheel while in a long bend is more pronounced than ever.
Also, auto wipers now detect dry salt and trigger wiping. So they smear salt on my windshield forcing me to clean it more often than necessary.
Finally, the GPS location has gotten way worse than ever. I basically can not drive in the right-most lane at all anymore or the car will slam on the brakes at every exit. I'm also having serious problems with the car thinking that it's on roads near the highway or over the highway, which leads to it wanting to drive 30 mph instead of 65. These problems are only getting worse, which only makes it more dangerous in my opinion. Now that winter has set in any of these jerky motions or hard stops have the possibility of causing my car to slide or someone behind me to slide and cause an accident.
Speaking of winter, the car still does not recognize snow or slush as a lane bounding item. So if a giant pile of snow defines the left or right side of your lane, the car will totally ignore it and still look for a line. This is again extremely dangerous especially when slush is present. Cars spin out all the time because they suddenly hit an unexpected thick patch of snow or slush and lose traction. This is something Tesla said that they would begin training their cars for, but there has obviously been zero progress. While this isn't new in the current version, it is still a very serious problem.
Sorry if I wasn’t clear but I thought Autopilot was Traffic-Aware Cruise Control and Autosteer. Both were engaged and active but no warning as I said.
Same. Nothing. LR AWD HW3/FSD - using TACC and auto steerUpgraded to 40.2. No stop sign warning during first test drive. What a surprise, Elon... what a surprise.
Thanks for the info as it lines up how I think it was supposed to work with the options I have. A work in the aviation field which never turns down an opportunity to use an acronym. Now I just have to remember them all for my my car now!You are correct, "Autopilot" is the umbrella term Tesla uses for the various driver assists, including TACC, Autosteer and the various collision avoidance assists. NOA, Autopark and Smart Summon are a bit more complex since Tesla group it under Autopilot in the documentation but split it out for sales purposes (the same, probably, will happen for FSD if/when it arrives).
Yep.Same config on my end.
Autosteer and TACC have also become jerkier over the last couple of updates.
For those having trouble detecting signs/ red lights find a stop you would go straight through, turn on EAP, as you approach drop speed to 0 mph. Then when safe scroll up to proceed. It should go off crossing the stop line. works every time for me.
But at this stage, after testing, it’s mostly annoying, because even if you bring the speed to 0mph, it still screams at you once you scroll up. Tesla needs to program if speed =0 then no need to scream as you re-accelerate through stop.
Yes I agree. Nevertheless, the update notes specifically say "auto steer". I can engage auto pilot but have to then separately engage auto steer. I find this requirement a bit odd, as I would rarely use auto steer in city/street driving.
Another distinction - Auto steer is included in both EAP and FSD. What I don't know: Does the stop light/stop sign warning work with only EAP or does it need the FSD upgrade?
Still waiting on 40.1 or 40.2. Not sure what the hold up is?
