Scrannel
Pretty basic stuff at this link (and I assume it's accurate) but does state Tesla "cords" have a cgfi built in.
Home Charging Wiring Guide | TeslaTap
Actually you kind of need something that can hold the main body of the mobile connector as well. It isn't weatherproof. One could even build a wooden enclosure if they liked.Awesome list! Thanks for sharing!
FWIW, you really need an “in use” weatherproof cover for EV charging (not one that just keeps the receptacle dry when not in use).
I have yet to see one of those with the larger diameter receptacle cover.
ThisI used an Enerlites receptacle with a 2 gang deep box and cover plate from HD. Seem fairly decently made. It's only been a little over a month but I leave the mobile connector plugged in.
I've not noticed any heating issues. Now, after reading this thread, I'm wondering if I need to swap out the receptacle.
https://www.amazon.com/Enerlites-Re...9Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
I used an Enerlites receptacle...
This
G4438388
and this
Hubbell Wiring Device-Kellems Single Receptacle Plate, 2 Gang, Silver SS701 | Zoro.com
Less than $50
This
G4438388
and this
Less than $50
And you will probably have to get a new cover-plate to fit the larger diameter receptacle; sorry. Check out Post #s 57 and 59, Page 3 above, for suggestions. After further consideration, I am going to try out the low profile, expandable, lockable, METAL MX7280S cover by Hubbell-TayMac (possibly available to order from Home Depot or Lowes, as well as on eBay and Amazon). This is an "in-use" cover that I hope can be locked with the 14-50 plug still attached, for added security and weather protection. It uses inserts to allegedly fit up to 55 different receptacles. There is also a deeper 55-in-1 metal cover--MX6200--that will also take up to a 2 7/16" diameter receptacle.
Good luck.
Or just 3D print an outlet cover.
No, you don't have to start with a retail product. I did measure a Leviton cover plate for a rough overall square (technically a rectangle) size to make sure it covers a 2-gang box. Other dimensions came off the Bryant outlet; center hole size, through-holes for the cover plate-to-outlet screws, and provisions for the outlet-to-gang box screw heads. Filet edge was a design choice.WIBD. Neat. So do you have to start with a retail product item that you somehow scan/copy, or can you go to a library of pre-existing public-domain or for-purchase 3-D CAD files somewhere and look items up? So this process is for any topologically-simple part/object that can be made of plastic? Different grades and shapes of plastic to start with, I assume?
Advice requested...
Finding small lengths of 6/3 wire is harder than I thought. Luckily a friend who works for an electrical supplier has a bunch.
Is it a good idea to use an Aluminum sheathed wire ? or BX ?
Is it hard to cut and strip the sheath ?
Use copper if you can.
Sheathing is easy to cut. Just run blade down the length, parallel to wires and then peel it off.
This
G4438388
and this
Less than $50
This is for a Bryant 9450FR. Thinking about uploading the file to Thingiverse.com. If anyone is interested, let me know.
