paulp
A few posts up you complained about 3 letter acronyms. 4 letter acronyms are ok then?The Tesla HPWC is rated as IP55 so is fine to live outside.
Your right. The Tesla High Power Wall Connector (HPWC) housing Has an Ingress Protection (IP) rating of 55.A few posts up you complained about 3 letter acronyms. 4 letter acronyms are ok then?
If one end of the connecting device is in water your tesla wont be very driveable anytime soon.I was asking about the UMC though... But from what I've read from searches it seems the UMC is OK to be used as long as neither of the ends is in a pool of water
@meowsers nice pics and good setup. Debated dong something like that at my current place as we may be moving out within the next 12 months.
Anyone know if we will be offered what length (5 vs 7m) cable we want for our free HPWC when we take delivery of the car?
Yep there are plenty of destination chargers on poles on outdoor shopping centre car parks.Mainly because it will be almost a permanent outdoor fixture. Is the UMC weatherproof? Our powerpoint is indoors so I would just be feeding the cable through a hole in the wall.
install a 32A 1P outlet
It's actually a 2.6m vs 7.4 so quite a difference. They will most likely give you the smaller one, although I paid the same price (? I think) for the longer one, so maybe it is your preference. Who knows, you might ask them?
We're currently waiting on delivery for 2 Teslas and I was thinking of getting the electician to come around and install the HPWC and also install a similar outlet to the one you had put in. The idea being that if we ever needed to fast charge both cars at the same time, the outlet could be used with the UMC with an appropriate adapter.
Since I am no sparky, do you guys know:
(1) what that outlet is called?
(2) does that outlet work on 3 phase?
(2) whether there is an adapter for the UMC what would work with that outlet?
(3) is 11kW the expected output from that setup? (outlet + 3 phase + UMC)
I actually reached out to Tesla via email to specifically request the longer cable HPWCs for our cars, also offering to pay the difference if the longer one was going to cost more. Got a reply saying they've noted the request and that cars will be delivered with the longer cable HPWC. No requirement to make any top-up cost.
Once you’ve owned for a while you will work out the routine that should negate the need for fast charging.We're currently waiting on delivery for 2 Teslas and I was thinking of getting the electician to come around and install the HPWC and also install a similar outlet to the one you had put in. The idea being that if we ever needed to fast charge both cars at the same time, the outlet could be used with the UMC with an appropriate adapter.
Why don’t you install both hpwc and use the network functionality included with them so you can use them both together. When they are both in use they will auto regulate the available current so they won’t exceed the capacity of your circuit
The three phase 32A 5 pin socket is called a Clipsal 56SO532 which translates to Clipsal 56 Series (which have an Ingress Protection rating of 56 or more) SO for Socket, 5 Pins and 32 Amp rating. The plug is called a 56SC532, SC stands for Socket Connector.
N.B. Sometimes different versions of these plugs and sockets will have an additional character to indicate an additional feature.
The 5 pin version is for 3 phase and it’s what I installed initially prior to getting my High Power Wall Connector installed.
I’m guessing the single phase version will be 3 pins so a Clipsal 56SO332.
I’m not an electrician so use this only as a starting point to talk to the qualified person.
Umcs are generally limited to 16A and I understand model 3 umcs are only single phase. So while you could plug it in to a 32A 3 phase outlet the improvement over a 10A standard outlet would be marginal at best.Installing both HPWCs would be a option, but we visit the in-laws often enough that we thought it might make sense to have the same setup in 2 locations, i.e. 1 HPWC + 1 UMC (plugged to 32A outlet).
Not sure about V2 UMC but my V1 UMC can connect to a Clipsal 56SO532 with adapters.Thanks Meloccom!
Yep, was just wanting those details to start the discussion with the electrician.
You mentioned using it before getting the HPWC installed. Was that with the UMC? Does Tesla sell a compatible plug adapter?
If the V2 UMC is going to support the 11Kw Charging capacity of the Model 3 they will need to support 3 phase otherwise 7.2Kw will be maximum on single phase.Umcs are generally limited to 16A and I understand model 3 umcs are only single phase. So while you could plug it in to a 32A 3 phase outlet the improvement over a 10A standard outlet would be marginal at best.
That said, for daily top ups 10A single phase is more capable than most people give it credit for. Especially if you have one hpwc for a rapid top up when single phase isn't cutting it.
Ok so I've had another look and it appears 32A single phase is what you will get with the Gen 2 UMC. That's what they get in USA and Europe, but I guess until people take delivery we won't know.If the V2 UMC is going to support the 11Kw Charging capacity of the Model 3 they will need to support 3 phase otherwise 7.2Kw will be maximum on single phase.
I’m renting and the owner is not willing to put any skin in the game to install a higher current outlet in the garage, he told me I can go ahead and pay for it myself. He didn’t buy the “upgrade” and “future proofing” story.A little OT but I've heard of people installing a standard 10A 240V plug onto the end of the HPWC. Is this reliable/acceptable and easy enough to DIY?
