They're similar... PM or email us ([email protected]) for more info... it can be done@RedwoodMotors, the photos of stock and your product made me wonder - are the lower spring perches the same size? Looking for SCCA street compliant dampers.
So....I’m confused. What would you equate the ride of each of these systems too? What would be, say, E46 M3? The sport ones with the settings dialed back? What would the Grand Touring be? A Lexus GS 350?
will not be tracking. Drive consists of mainly concrete highways. But I don’t want a cushy ride. FWIW, I owned a GS350 FSport and thought it was too soft, even with the shocks on stiff. I also had an F10 535 with dynamic handling and that was too soft also. I think the F10 M5 and F80 M3 are too harsh. Too stiff without enough performance benefit, IMO. E92 M3 was also good. 991.2 Carrera without Sport PASM is perfect.
They're adjustable, so to some extent they both have some capacity to overlap with each other - but, the fact that you track your car probably puts you into the Performance camp. We really only started the GT project after getting questions from potential customers saying essentially... "I don't really care about handling, I just want this thing to be more plush/comfortable, and I'm coming from a [insert luxury sedan brand here]". There is some overlap, but the fact that you track your car at all most likely puts you into the, go fast, optimal handling camp.This sounds like a great option. Redwood, can you maybe clarify a little more?
Asked a different way: given a driver who only goes to HPDE/auto-x a couple times a year at most on street legal tires (dedicated set), but commutes a ton and enjoys spirited back road driving, would the Performance Sport or the Grand Touring be a better match for them? Or could either set be adjusted to be acceptable for that kind of driver, generally speaking?
They're different... the rest of the hardware is the same, but the springs and valving are different for the GT kit. We are running softer springs (also being made by Swift). The new valving curves are currently in development / testingSurprised that the sport and touring versions would have the exact same springs.
My question is if GT is using same digressive valving how it would smooth out the ride at low speeds? Do you still feel the bumps and potholes like stock? What about high speed freeway cracks and lines? With stock going over each of these lines gives me a headache. I’m reading we need linear valving and progressive springs for smoother ride but you pay the performance penalty. How is ohlins dampener different from KWs?
That was the same thing I thought at first but after reading through it again, I realized that it says same springs but "reduced spring rate". Presumably meaning that they are the same Swift springs with the same type of steel, just a different rate.
@RedwoodMotors any more info or feedback?
Also, can you tell us where you stand with regard to # of sets ordered in the initial run for both sets, and when you might be shipping?
Thank you.
Not in this particular location we've used for the spherical but big performance gains since the Ohlins DFV piston senses how much damping force to apply based on linear shaft velocity (so any rubber on the shaft mount side creates a fraction of a second delay, slowing down the response of the shocks. In the future, we may remove the spherical on the GT kits as performance is less of a priority (and removes a little additional cost) but for now it will be included across the board on all kits, as NVH is not significantly affected but the performance benefit with specifically the DFV piston is worth the additional parts cost.Any noise / nvh concerns with the spherical bushings?
I apologize in advance but I have a newb to coilovers question for either @RedwoodMotors or anyone else with experience. Given that these are height adjustable, how easy is this to do at home? Would I just be able to raise the car, remove the tire and make the adjustment or is it more complicated and possibly require a trip to a shop?
I’m interested in lowering my P3D 1-1.5” and I’m reluctant to use springs after having adjustable air suspension on my previous car. I like the idea of being able to raise the rear .5” for example if I am going on a trip and know the car will be loaded with people and luggage. I’m also interested in the ride quality and it sounds like these would be really nice coilovers in that regard as well.
Thank you for any info anyone can provide.
That's honestly a good analogy between the BMW M suspension and more luxury-oriented cars. I've personally been testing the beta performance shock set (what we're now calling "Performance Sport") and I think it's great for a daily. I'm 38, typically am in a sports car if not in the Model 3, and to me the performance setup is completely non-offensive for commuting, picking up family, etc. Yes, it's on the performance end of the spectrum but holy **** does it grip, transitions are sharp and quick but poised, and launches are fantastic. Globally... with the Performance Sport Ohlins, you definitely feel connected with the car. Zero vagueness, zero complaints... truly feels like a sports car, and you forget you're driving a 4000lb sedan.
However, if your goal is to drive to work and back and are disappointed with the comfort level of the *stock* suspension, the Grand Touring kit would be more up your alley.
Performance Sport: Phenomenal handling - Good ride quality (I would personally rate it as better than stock)
Grand Touring: Good handling characteristics (again better than stock) - but focus on improved ride quality and comfort
I am interested to upgrade my model 3 suspensions with aftermarket Coilover. The main shock body is made by Öhlins and Redwood has modified to fit model 3. Please advise who will own the warranty of the kit?
How often do we need to rebuild the Coilover for normal street drive use?
Rebuild? How about never. If you mean adjust the shocks that's another question.
Dampers are a wear item. Rather than trashing them, the higher end ones can be rebuilt.
Bump.....Do you guys install? Im up in Montclair, about 20 mins away from you lot.. Also, what about ride height drop, is this easy? up and down? Up for standard road duty and low for the occasional track day?
They only need to be rebuilt if you blow or overload valves and seals. If you're running them mostly on the street, and the shock becomes a bit softer you simply dial up the shock to a firmer setting. I've had probably 10 sets at least of adjustable shocks, and I've never had to have one of them serviced for wear ever. This despite keeping many cars many years.
Do you live in CO? Are you getting Ohlins?
benchmark of the luxury ride to me is Lexus. I need car to drive around town to run errands, go to work, and some long drive over the weekend. I'm not into sports racing nor care much about track performance. roads are bad enough in NE. That being said, which Coilover, spring can be considered equivalent of Lexus type softer ride!!??
Anyone?
