Can you briefly explain the risk when removing the PPF? I'm somewhat aware of issues on prominent sun-exposed ares like the hood, but what's the risk for this rocker panel area?The risk comes later when you remove the PPF.
I'm wondering why this issue of paint damage from normal use hasn't been more frequently discussed on this site considering the Model 3 is about 2 years old now with over 100k cars on the roads. A significant number of cars have already gone through at least one winter in the US.
If it was happening on all or even most Model 3s, wouldn't there be a lot more discussion here? I've been to Finland a few times and from what I recall (last time was 4 years ago), the road conditions there are different with more loose gravel, but I would think there are least some areas of the US that are close enough.
Is it only happening in areas that use sand on the roads?
See this is where we differ quite a bit. Having done contacts with US and EU companies, on the US everything and all edge cases need to be mentioned and agreed. Here in the old world we tend to have a bit less of a "**** you" attitude and can have expectations on what a product, a car in this instance, needs to withstand before starting to show signs of wear and tear.
Puuh, the consumer protection laws in Finland and in the EU when it comes to buying cars (used or new) are actually worse than the US ones. So there’s that. No lemon laws, no proper car history tracking etc.
For reference, my wife's car had about 22,000 miles on it, and looked like it had 22,000 miles on it, in the exact same rocker sections. Her's was what I consider 'normal'. Actually a bit worse than normal, but I'd take it as acceptable, but not ideal.
My car (same black model 3) shows MORE wear on the rockers at 3,000 miles.
So, I don't believe this affects all 3s. Also note the S, X, and Y all have lovely durable plastic covering the rockers.. as nature intended. It may not be as cute, but my S's sides were flawless after 60,000 miles.
Most of the pictures showing paint problems are from black cars. Could the black paint be more fragile than the other tints ?
True, however the red seems to be beaten badly and it is the pricey. I wonder what colors are the cars of the folks who didn't encounter the same issue.Well it is the cheapest.
Good luck with the claims. No way in hell will any of you get your vehicles repainted. It's not just the rocker. The entire side would need to be painted in order to match the paint and not look like a.$$ GOOD LUCK WITH THAT
No, I haven't. Also I am wondering how come you have some much differences between cars then.
I didn't know that actually, I appreciate the info. It sucks for the unlucky oned...Do remember that the paint coverage between the cars varies surprising amounts, even if they are painted by robots and by logic they should be able to do the exact same paint job over and over again. But they don't.
It wouldn't surprise me if the composition of the paint as well as the amount sprayed varies between the different batches of the cars.
I also want to see these aluminum rust photo's....
