Hey Vgrinshpun,
A couple of corrections to your statements:
When tested to the EPA standard, the car is driven until it stops moving or enters "turtle" mode. They do not stop driving the car when the indicator shows 0 miles remaining.
When 0(+) rated miles are shown remaining to the driver, this does not equal a SOC of 0%, rather ~6%.
Peter
Peter
The EPA numbers that are used by Tesla as the "Rated" capacity of the battery actually indicate that battery is 85kWh, but 5% of it is "reserved", i.e. when battery indicator shows 0 rated miles (0% state of charge), there is actually a 5% reserve left in the "tank".
The numbers used by EPA and Tesla:
Rated range = 265 miles
Rated power consumption = 0.3kWh/mile
Using above assumption that 265 rated miles equal to 95% state of charge of 85 kWh battery, the calculated rated power consumtion:
0.95 x 85 / 265 = .305 kWh/miles, i.e. essentially the same number used by EPA and Tesla as rated power consumption.
There is another interesting number used by EPA as overall power usage: 38kWh per 100 miles driven. I believe that this number is higher than rated number because it takes into account charging and battery efficiency as well as vampire load.
