1 (200A) fuse instead of 2 (100A) fuses, and rotated 90 degrees. That's what I'm seeing in the comparison.
There is a second one, the white piece of paper you see underneath the fuse is hiding the second one.
They should take back the old ones and offer them to hotels for free if they are willing to install them. 60A plenty fast for overnight.
Looks to me like the whole left side (feed) is changed. It should be an exchange and reinstall, not new fuses.
I hope it's that "easy". I'd love to not have another visit from the inspector because the whole unit had to be replaced a second time. I get stress and annoyance for at least two weeks (sometimes more than a month) every time I have to deal with the "I won't coordinate via phone, email or anything but just show up randomly and not do the job because the garage door isn't open 24x7" inspector shuffle. Another reason for me to hate government involvement in my affairs.? Looks like you just replace the fuses and the busses they're on ... in other words, unscrew replace at these points...
TPN: 1011831-99-B
TSN: T12J0000814
TPN: 1011831-99-B
TSN: T13A0002657
My (2nd) HPWC from December:
TPN: 1011831-99-B
TSN: T12J0000814
Denarius HPWC:
TPN: 1011831-99-B
TSN: T13A0002657
PSN: 1008488-99-C
TSN: T13F0005046
My external label is the same as his.
Ah ok. Thanks for the correction.My (older) HPWC box has 1008488-99-B (rev. B). So rev C is the fixed version.
The 1011831- part number is the HPWC unit itself, while the 1008488- is the whole package.
I see what they've done, and it appears my hunches were correct.
The RMS current (apparent power) was a bit too high for 100 amp fuses, and was burning through when charging for prolonged times, and the fuses are now rotated so the heat doesn't collect in the metal cap at the top of the fuse, likely where it's burning through. The new horizontal orientation of the fuse allows heat to dissipate evenly upwards across the entire fuse, instead of building up as it travels up the fuse body.
My hunch is that for existing units, they will likely work just fine when replaced with 200A class T fuses in the vertical orientation.
Last week I replaced all fuses in my two HPWCs with 150A fuses. A 100A fuse was blown in each unit. The
I don't see why they didn't just replace the fuses with copper buss bars since the unit is connected to a circuit breaker.
