A few ways to do a rough assessment:
(1) Look at your electrical bill. Your current usage per month will be measured in kilowatt-hours. Divide by 30 * 24 = 72 hours per month to get kilowatts; multiply by 1000 to get watts; divide by 240 Volts to get amps. This is your average amperage load. Guess that your peak load is no more than twice that if you have a typical day/night usage pattern. Do you still have enough "headroom" in amperage for your 80A circuit? (And are you actually going to use that circuit while everything else in the house is running? -- if not, you probably only need enough headroom over average load.)
(2) If that looks good, but you're still worried about peak load -- look at your existing 240 volt circuits and add them up, ignoring the 120V circuits which are probably insignificant for peak load.
Finally, if your amperage load is high and you don't have any 240V circuits to speak of, figure out why and reduce it. It's likely to be lighting, which is easy to fix. Lighting load is startlingly enormous in most houses. I switched from incandescents to LEDs across my 2 bedroom house, and saved enough electricity to power my car.
So yeah, I wouldn't worry about your 150 amp circuit unless your house is an energy hog. If you have a lot of 240 V electric appliances and you run them all at once, however, then you should add it up.
