Good guess, I hadn't thought of that. I think you may be right. The way the window abruptly ends (at ~90 degrees) near the rear "spoiler" doesn't seems likely, and the more rounded feature under the wrap is likely the true edge of the window.
There are abruptly ending rear windows in some cars, though, with automated spoilers - at least Panamera is very similar:
Why would they wrap a thin strip at the base of the rear window? What could they possibly want to hide there? AnxietyRanger?
Good discussion, thank you guys.
I think we need to remember, when we first saw this setup - it was on a black mule (may be the same we are seeing here but had different bumper) - an additional piece covering the rear part, the middle one here:
Also the white one had something there once:
That said, I think the answer is one of two:
1) Both versions (black and white) that show extraneous parts in the spoiler sector are merely camo to make the mule look like the original 2012-2013 prototype (which is topmost in the picture above) and hide this change (much like front roof is camoed to disguise the fact that there no longer is a central beam between A pillars on the mule). In this scenario the latest black mule would actually reveal the final or near-final version of the rear window.
2) None of these mules show the exact final version of the rear spoiler area, but may show some camoed or obsoleted development versions instead. Final might be something completely else.
I'm not fully convinced the white camo with depressions in the rear spoiler area is merely camo. It could be the underbelly of what is showing on the black mule above. Maybe they were testing an extending spoiler or a rear wiper at some point and this is related.
Of course, it all could be just camo or obsoleted parts - even the latest glass-looking one.
- - - Updated - - -
There is still something showing through and the window bending a little weird where the camo used to be. Is it a full piece of glass for sure, or could it still be a sign of camo or something more dynamic than merely a big window?
Of course whatever showing through could merely be interior camo/tape or a trunk cover showing through.
- - - Updated - - -
What if the rear glass is two-part, hiding either an automated spoiler and/or a rear wiper under the horizontal piece of glass on the lower end. That would explain why the edge of the glass looks like it is made from two pieces, although I must admit the central seam is almost seamless at least from this distance, if this theory is to hold water. A separate part on the lower end would also explain why the trees reflect so differently from that section (although being concave could explain it too).
