My quotation marks
If you cannot write at least semi-quantitively, you are spouting BS.
The difference in height is 80 Vs 70, so if that was the only difference the 2170 cells have a 14% wider spread when the chemistry and capacity are the same.
It seems intuitive that as the cell circumference increases, so does the gap area between cells so the final spread of equal material of the smaller cell will be less than 14% more than the larger cell. I am not sure by how much.
Not we -- you. And you are confused
The improvement in driving dynamics was talked about in the context of the moment of inertia. Can you see how a taller cell would have that effect, all else being equal? I don't think it is difficult to understand even though my understanding of physics is close to nil compared to Elon.
Look, the current Austin car is just not up to existing MYP standards, let alone the Battery Day hype. Only fanboys could believe otherwise. This discussion is a full waste of time. Putting you on “ignore.” Thanks for playing.
