bkp_duke
Yes, understand all that. The magic number you are looking for is 69 for the “bandoliers” however that is only 255V which is low so I am not sure what voodoo is going on with wiring to get to 350-400V for the whole pack. There are 12 bandoliers so removing 1 would be an 8% reduction in Paul capacity if that doesn’t mess up the voltage. But it would be unbalanced weight wise unless they shifted everything around inside which like posited before, is re-engineering the pack.
And while Panasonic has a pilot line running, they are delaying volume production to 1H FY25 to make better cells so they aren’t currently supplying any to Giga Texas. So thats at earliest April 2024 to start the ramp for Panasonic.
You do realize that there is space in the current 4680 pack for 2-3 more bandoliers? See Munro's teardown.
You simply re-center the cells you have, problem solved. There is nothing in the structure that would prevent this.
Back to my MAIN POINT - Elon has made it CRYSTAL CLEAR on many occasions that if given the choice between longer range, and using cells to make more cars but keep range constant, they will chose keeping range constant and building more cars.
