CrewKize
Well are on! Thinking they will work. 19x9s
@CrewKize,
Nice! Looks great! Comfort or Sports? Brief thoughts and review would be appreciated after you get some miles. I know it will be awesome. What are your wheels Stats/Specs? Enjoy!
Ski
Sweet....so your running 12/10 on Compression and Rebound I believe it is? Yeah...I’m favoring getting the Sports over the Comforts. Haven’t pulled the trigger yet. Chomping at the bit of course!
Ski
@MountainPass - I posted this on the other thread (on the comfort coilovers) where I suspect you guys might have missed it, but it really belongs here. Much of it relates only to the Sport kit (which of course is fabulous!)
Couple of questions –
1) I know the conventional notion is that compression firmness impacts handling more, while rebound firmness more the suppleness of the ride, but is that how you would describe and understand it? It seems like a little bit of an artificial distinction between ride and handling, and if this popular notion were so, why wouldn't people simply really back off on rebound and keep compression really high?
2) Where do you guys run your set up on the street in terms of ride height and shock settings? Do you tough it out, or go with the 12/10 baseline?
3) How do you set the shocks for particular tracks? Trial and error? Speed of corner/degree of compression? Just wondering what the heuristics are in a general sort of way?
4) I'm curious why you guys have as the default setting (12/10?) slightly different compression and rebound numbers (12 clicks off full hard for compression and 10 clicks off Full hard for rebound)? My understanding that the general design/functional parameter is that slow to medium movements are dampened more aggressively as you go towards full hard but superfast compressions/actuations are not? Is that correct?
Thanks again for all your support. We love your stuff – keep it coming! Speaking of which, when do you think your front camber/caster arms are going to be available?
best, Doug
I am very happy with my new Comfort Coilovers from Mountain Pass Performance and KW. VERY happy. The car is definitely more comfortable and better handling than stock.
They were installed yesterday at West End Alignment in Gardena, CA, which I also highly recommend. Chris is fanatical, meticulous, prompt, and communicative.
The vibrations coming into the cabin are reduced. “Muted” is the word that immediately came to mind. “Muffled“ may apply. I was aiming at road defects and smiling.
It is quieter. Sound is vibration, so less vibration means less noise in the cabin. I never heard anyone say that. It was a surprise to me.
It clearly corners much better, with less body roll. Clearly. More smiles. The flatter cornering adds to the comfort as well as the excitement. I don’t know why MPP doesn’t claim this. There must be ways to measure it so they can. If there’s no app for that, how about a bowl of water on the floor, and measure the spill?
Of course it looks better. It looks right. My installer agreed with the MPP height recommendation. Mine are set a few mm above the MPP recommendation to allow for slight settling.
The stock setup was annoying. Now my M3P rides like the German cars I am used to. The only downside besides the time and money is that I will probably wear out my tires faster now that it corners better.
Would you recommend this mod for a daily driver with no intention of tracking the car?
I had a local shop install my MPP sport coilovers yesterday and when I got home I noticed that the fender gaps on each corner is different. Measuring from the ground to the fender I have these measurements: RL: 27"; RR: 28"; FL: 27.25"; FR: 27.75". The difference between rear left and right is so great that on one side I can easily fit my hand in to adjust the rebound wheel while on the other my hand won't even fit.
I called the shop back and they said that I should not measure like that because the ground may be uneven. They claim they measured the perch distance evenly for all corners so that is the correct adjustment.
So then I parked the car in the same spot but reversed so if there was any grade affecting the gap it would be reversed. The gaps measured the same. Seems like if there was any grade on the ground it made no difference. But why would there be such a gap difference if the perch measurement was done right?
Have others with MPP coil-overs noticed the same thing and should I just live with this? It kind of bothers me every time I look at it. BTW, what should the ground to fender distance be as per MPP spec?
Is the OEM isolator the rubber part that is right against the top chassis mount in the fronts? The one with three holes where you need a narrow socket to take the bolts off? I see a rubber part (looks dirty so I think is original) between the chassis mount point and the aluminum looking thing below it (which looks clean). It's there on both sides. These are the only rubber parts they gave me back.Those variations are simply way too large and suggests that the install wasn't done properly. Their rebuttal was frankly pretty flaky and very unlikely in terms of variations that large. I'd check and take pictures of each suspension corner/spring perch, and see if they look at all asymmetric side to side. If so, that's more evidence that they didn't do something properly. The other thing to check is if they used the stock OEM isolator at the top of the assembly on both sides or just one side, (it sits just underneath the MPP aluminum column).
I put my car on the rack and checked the installation. I was able to see that they did install the OEM rubber isolators both sides and the back has them too. To me the install looked fine but I counted the treads remaining from the perch to where they end and the count is different on every corner. Looks like they didn't measure properly like they said. Also in the front they had the damping set to 0 on one side and 5 on the other. I could not find the damping adjuster on the back. Found the rebound on top but could not see anything on the rear bottom. How are those adjusted?
1. When they say 10 clicks open from full stiff. Were is full stiff?
2. Some of the adjustment dials have numbers on them and a notch to align them too. Are we not supposed to use those and count instead from full stiff?
