Perry
On everything except the rear rebound, clockwise direction is obvious. How to I determine the clockwise on rear rebound since you see the dial from the side not top or bottom?Ignore the notch for now, unless the installer has calibrated the adjustment knock with the internal click. Turn clockwise until it stops, this is full stiff. Don't over muscle these, the internal screws that the knobs are connected to are small. Then turn counterclockwise and count each click you feel until you reach 10 or whatever number you want to set. Just don't pass 16 clicks counterclockwise(if you accidentally go over by one or two, its okay). Each click requires 60* of rotation, a full 360 rotation has six clicks.
Don't understand this phrase: "loosen the set screw on the adjustment knob, so the rotation of it is not driving the internals"To calibration the adjustment knob to the notch. At full stiff loosen the set screw on the adjustment knob, so the rotation of it is not driving the internals. Adjust the knob for 0 is be aligned with the notch, tighten the set screw.
I presume this is to late to do if coil-overs are already installed.
