I've just set mine off too. I'll check later to see if it has worked unattended
Same here....
I'm on 20.17 and getting this nav data update.
I’m N the same. Just on the way home to update but still stuck on .17. M3PNav update downloading now..... LR still on 20.17 and refusing to acknowledge that a new release is out there
How long is download taking on average? And is it able to continue off-wifi?
Nav update hasn't fixed the postcodes problem. Even selecting from a fixed marker from the on screen map, navigation only uses part of the postcode and navigates to wrong side of the road. Note same road name but different postcodes (PO7 7NU / 7NX), intersected by a dual carriageway, odd numbers one side, even numbers the other.
Satnav only uses road name + PO7, even when given PO7 7NU. Not much use when you have multiple London Road, Station Road, Church Street etc in same district and they could be quite some distance apart, or in this case, one road separated by a dual carriageway.
