I know the point I am about to make has been addressed before, but in light of what Ingineer is about to test .... If you're going to pull the battery, why wouldn't you just put a trickle charger on it? I know that we shouldn't need a trickle charger, as the traction battery should do that ... but either 1) it isn't or 2) it is, and the deep discharges that are happening kill the battery off in < 1 year anyway. If it is (#1), and the problem is deep discharges while driving, then taking out the battery shouldn't help, no? If the traction battery isn't adequately 'trickling' to the 12V (#2), then a trickle charge should work at least as well as removing the battery. No? The other question I can't help but ask ... if the Telsa stays plugged in when it is home, why is it that the car doesn't keep the 12V topped off completely? Is the process of 400V -> 12V inefficient, or does this type of battery get damaged by too frequent charging? And if the 400V -> 12V is inefficient, why can't it take the power from 120V of your electrical service to trickle the battery directly (like a trickle charger does?)
