crackers8199
i have a similar (but different) question, kinda related to this though so i'll ask it here.
prior to the model 3, my daily driver was a 2013 chevy volt that is now my wife's car. when we had our house built, i had it built with a 14-50 outlet installed in the garage to charge the volt...but since the onboard charger in the gen 1 volt can only do 3.3kw, i just bought a clipper creek LCS-20 and threw a 14-50 plug on the end of it, plugged it in and called it a day. worked great.
now that we have the model 3, the volt parks on the other side of the garage so i can charge the model 3 from the 14-50 using the UMC that came with the car. what i'd like to do is put the CC LCS-20 back into service on the other side of the garage without spending a fortune. there's no 220 outlet over there, but there is a subpanel that is directly on the other side of the wall from the main electrical panel outside. it runs on a 50 amp breaker from the main panel, and has two open slots. it mainly powers the lights and outlets inside the house (and a separate independent circuit for our garage fridge), the other bigger stuff (such as the 14-50 for the model 3, AC, dryer, oven, etc) is wired directly to the main panel outside.
my question is this: can i install a 20 amp double pole breaker in that two spots that are still open in the subpanel and use that to power the LCS-20 for the volt? what do i need to look for to figure out if that's something i can do?
