Watts_Up
The technician was able to correct the toe, but informed me that in the future there might be a need to use a shim kit.How much of a toe range is there for adjusting? Can more toe be dialed in?
Note: I was wondering if towing mode would be use to perform the alignment to allow free rotation of the wheels.
One issue I know is that the transport mode lasts only 20 minutes, so you would need to reactivate it quite often.
Otherwise, Neutral would requires to have a person sitting on the driver seat seat.
However, here are the instructions for keeping the car without getting in Park mode:
1. Buckle the driver's seat belt before sitting in the seat.
2. With the key fob inside the vehicle, sit in the driver's seat and press the break pedal to turn the vehicule on.
The speedometer and PRND are now displayed on the instrument cluster.
3. Shift the vehicle into neutral. This release the parking break.
4. Without leaving the seat, and with the brake pedal still depressed, open the driver's door
and use a pen or a small screwdriver to engage the door latch to its fully closed position (second detent).
This causes the vehicule to behave as if the door is closed.
(To release the latch, pull the interior door handle.)
5. Exit the vehicle, it can now remain in neutral with the parking brake off.
(To engage parking brake, shift back to Park.)
