New design - With no stalks how do you change directions or signal?
Discussion in 'Model X' started by jboy210, Jan 27, 2021.
  1. jboy210
    jboy210 Supporting Member
    Northern California
    Not a fan of the yoke, but flew behind one for years so I guess I can used to it. But what is up with no stalks? Anyone have any idea how you change from forward to reverse to park? How about signaling and controlling windshield wipers and autopilot?
  2. andrewdtran
    andrewdtran Member
    Houston, Texas
    Yeah that's definitely one of the new quirks I'm trying to figure out
  3. stonelance
    stonelance Member
    Seattle
    Looks like there are buttons around the scroll wheels, but also probably on the touch screen for wipers (like the Model 3)
  4. moa999
    moa999 Member
    Sydney, AUS
    On the Configurator site you can see 3 what look like soft-touch buttons on the left side - left/ right indicators and headlight.
    In the right maybe 4 buttons - autopilot, voice, wipers? Phone? Screen control?
  5. cusetownusa
    cusetownusa Member
    Syracuse NY
    Not a fan of the steering wheel. Might be what keeps me from ordering an X.
  6. Mr X
    Mr X Future Martian
    Simi Valley, CA
    You won't need to signal with 2.5 0-60
    • Funny x 12
  7. DoctorVenkman
    DoctorVenkman Member
    Los Angeles
    Agreed with all of your points. My major concerns are:
    1) What happens with a digital gear shifter when the OS crashes? I've had the MCU crash a number of times, I'd hate to get stuck in drive because of a software bug
    2) How seamless is it to shift gears? Try to imagine doing a 5 point turn, or parallel parking in a tight spot, if you had to press a button on the screen each time to change gears
    3) What is the turn ratio on the steering wheel? Is it a half turn in either direction like a true yoke? Or will you have to do multiple revolutions to get full steering?
    • Like x 4
  8. moa999
    moa999 Member
    Sydney, AUS
    #8 moa999, Jan 27, 2021
    Suspect the steering ratio will be variable.
    Like current 3/Y at highway speeds.
    Highly geared at slower for cornering without moving the wheel over 90°.
    On the shifter. Much like the 3/Y suspect the gear select method (probably a up down button) will be part of the subsystem, so operate even if the MCU goes down.
  9. dss33
    dss33 Member
    Seattle
    Everything controlled via the steering yoke (turn signals, shifting, horn, etc.) doesn't need the MCU to function. You won't hear things like turn signals when the MCU is restarting, because the sound in the cabin comes through the speakers which are controlled by the MCU, but the turn signals themselves will still work regardless of the state of the MCU. The gear shifter will work similarly.
  10. dss33
    dss33 Member
    Seattle
    Interesting...
    "...force touch controls for 'Park, Reverse, Neutral, and Drive’ drive modes at the base of the phone charger on the center console."
    Tesla's new steering wheel comes with Autopilot sensor-based drive modes, force touch buttons, and more - Electrek
  11. tashtibet
    tashtibet Member
    fort collins, colorado
    everything on the wheel -more focus on FSD
  12. User01
    User01 Member
    Detroit, MI
    • Informative x 2
  13. TrevTremaine
    TrevTremaine Member
    Toronto, Ontario, Canada
    I've read the link about directional controls and don't like the idea of putting the gear selector waaayyy down by the Hazard button. I'm wondering if it wouldn't make more sense to make it one of the scroll wheels (maybe/sort of/dunno)? The idea of reaching down below your line of sight each time you have to change gears doesn't make sense.
  14. dss33
    dss33 Member
    Seattle
    They've done this in large part because Autopilot will now also select your gear. It sounds crazy, but it's a feature they're rolling out on the new S and X.
    https://twitter.com/elonmusk/status/1354680585139187713?s=20
  15. TrevTremaine
    TrevTremaine Member
    Sorry, still limited because: 1) AutoPilot cannot always understand what you're thinking, 2) right now, with AutoPilot it's a best guess and that right now has been prone to failure/incorrect responses. Go back to maneuvering to adjust a parking position, moving to a parallel spot for convenience or any other ad-hoc maneuver. You still need to be able to quickly override whatever the car decides. Again, if you need to reach down to where I've heard the buttons are supposed to be placed (down by the hazard button), it's essentially an after-thought and a poor decision. It needs to naturally fall wherever your hand would normally fall/sit.
  16. DoctorVenkman
    Los Angeles
    Anyone who's tried to use auto park or summon will realize that the car selecting the gear for you is a terrible idea.
    • Like x 6
    • Disagree x 1
  17. dss33
    dss33 Member
    Seattle
    I don't disagree with you, but the "shifter" will also be on the center display. They've assumedly done a lot of testing on the UI and UX of this so while there's a sense that it's too early to do this, maybe it's more just a change as opposed to a bad change.
  18. TrevTremaine
    TrevTremaine Member
    So, here's situation I'm concerned with: you put the car in reverse to back up but the car changes it to move forward. If you press on the pedal and move forward and hit something - who pays? Is it "driver error" or AutoPilot error even if in beta?
  19. drtimhill
    drtimhill Active Member
    Seattle
    I'd put money on it actually shipping with a regular wheel .. those yokes are basically non-starters for domestic driving.
  20. DoctorVenkman
    Los Angeles
    Yep, this exactly. I guarantee you there will be tons of accidents where someone is assuming the car is in one gear, hit the gas, and realize it's going the other direction. Once people get used to the car selecting the gear for them, they won't bother checking to see if it's right.
