My car resets consistently to 0 across the board.
Mine does as well, but only after the next day or after 11:59pm.. I can drive it all day with the new settings, run errands, etc.. at night still fine..
Get in the next morning and BAM! all 12's
Well, this is interesting: the values were all back to 3.5 this morning. That supports what @supratachophobia observed, i.e. the highest value is the one that sticks. I thought I had set some higher values than 3.5, but it could be that I was mistaken and when I stopped flddling with the equalizer, 3.5 was actually the highest value.Time to do some science. Since my equalizer levels were all reset to 3.5, I set one of the two midrange sliders to 2.0, then set another to 2.5 and dismissed the panel.
Next year (i.e. tomorrow morning), if the settings are still 3.5 across the board, we'll know that it's the highest value which is remembered. And if the settings are all 2.0, then it's the lowest value. But if the settings are all at 2.5 in the morning, that will indicate it was the last value modified.
Same.Mine sets everything to whatever my highest (treble) value is set to. For short stops it doesn't reset, but overnight or if I leave it parked at work for about ten hours it does. Whatever I set my highest EQ slider to, that's where they all reset. Able to reproduce continuously.
Very annoying!
Come-on now, its easy.
I have new vehicle with 2.50.180, and have read this thread fully, but only tested Fob related topics of 2.50.144 on
prior MX vehicle. My EQ observations:
Never bothered to reset after delivery on 12/31/16
Did observe the EQ setting loss overnight(s), donno to what level they all went
Screen frooze today 1/2/17, did the Ohmman scroll-wheel reset technique
Then set some of my fav EQ settings (#1)
After 3 short stops, my fav EQ settings (#1) remained (this all within a same day)
Then I changed EQ settings (#2), also today, then did the Ohmman scroll-wheel reset technique again
Then I observed EQ settings (#2) remained upon boot-up
Now let's see what settings are active 2morrow morning. I expect all settings will be lost (the bug).
BTW, I'm a guitarist & drummer, and it's easy to tweek EQ anytime if I want. Come-on now, its easy.
Right! How about going to final solution in next step. Make/save yer 5 favorite EQ settings, then Voice Command 1,2 ..5 and it becomes active hands-freeAnd it gets even easier/faster when you have to do it every time you get in the car. I'm pretty quick at getting them back to my preferred settings now.
EASY buy annoying, especially when I realize at 80mph I need to tweak. NOT SAFE. NOT practical. FIX IT PLEASE Elon.
<SNIP>
I called Tesla about it anyway and the guy thought it was funny but said they will look into it.
He also said the save feature in the equalizer setting for audio will be fixed in the next update.
From another thread:
(I added the bold.)
Sheesh, I'm glad he found it funny...
More data, even more confusion!Well, this is interesting: the values were all back to 3.5 this morning. That supports what @supratachophobia observed, i.e. the highest value is the one that sticks. I thought I had set some higher values than 3.5, but it could be that I was mistaken and when I stopped flddling with the equalizer, 3.5 was actually the highest value.
Tonight I'll try setting a different high-water value and see what happens.
3.5 -- 3.5 -- 3.5 -- 3.5 -- 3.5
5.5 -- 2.0 -- 3.0 -- 4.0 -- 5.0
6.0 -- 6.0 -- 6.0 -- 6.0 -- 6.0
One thing everyone that has this problem should do is send an email to Tesla [email protected] explaining the issue in an easy to understand way.
I can confirm that it doesn't reset back to the highest value. Our regularly reset to 1.0 for a few days although we had higher values set and then yesterday decide to reset to 3.0. It's like a little surprise every time we get in the car.More data, even more confusion!
1. Started with these settings, which had automatically reset overnight to be all the same value:
2. Changed the settings as follows:
3. In the morning, I had these settings:
This new high-water mark, 6.0, was not any of the previously set values!
Sure hope to see a fix soon.
