Ah ok.I did look into the Hildebrand products a while ago, but unless something has changed recently the issue is that although they have a SMETS2 compatible product they only supply it directly to energy companies, not to end users...
I'm trying to work out what I might save from switching from diesel to electric, including moving from my current tariff (NPower) to Octopus Go, but I'm not sure if what I've done so far is completely accurate/realistic:
20,000 miles per year x an average of 0.28 kWh per mile = 5,600 kWh @ £0.05 = £280.
However, is 0.28 realistic - I know it depends on so many factors, but from a trawl through the forum looking for what people were getting it would seem to be somewhere around the middle of the range?
I know that all my charging won't be at the off-peak rate, but most should be, and that which isn't should be offset by the charging I will be able to do for free on the Charge Place Scotland chargers?
The Octopus Go tariff has a slightly higher standing charge than my current one, so that adds another £24.
Then I have an adjustment in my gas tariff/standing charge as a result of the switch to Octopus which saves me £145.
I know that the Octopus Go tariff includes VAT but are their gas tariffs the same?
So overall an annual cost of £159 which equates to £0.01 per mile.
I can't help but think I must be missing something?!
When I compare that to my current car:
20,000 miles per year @ an average of 38 mpg = 526 gallons @ £6.14/gallon (assuming £1.35/litre) = £3,230
So a saving of over £3,000 per year.
Looks OK but a couple of points .I'm trying to work out what I might save from switching from diesel to electric, including moving from my current tariff (NPower) to Octopus Go, but I'm not sure if what I've done so far is completely accurate/realistic:
Thanks but apparently not SMETS2 compatible otherwise I think it would have been what I was after.
I might still contact them now I know what meter I have as it’s not obvious what is or is not supported.
I'm wondering if there is an open source zigbee based project anywhere that accesses the data locally as per the IHD.
* the limitation of 30 minute updates seem to be a battery saving feature to allow the battery of a smart gas meter to last 10 years,
It's an interesting exercise but I would be wary of making the switch on the basis of how the numbers happen to work at the moment. Certainly in the future there will be some shifting around of EV related taxes and costs. Thankfully we are still at the stage of not wanting to discourage EV take up ... but ... One of the reasons that electric power is so much better value than diesel or petrol is not just because it is intrinsically cheaper and more efficient but because we do not presently have any specific vehicle fuel tax on the electricity we use for our vehicles. If petrol and diesel was taxed like electricity the numbers would be significantly different. The loss to the taxman if/when we are all driving electric means that at some point the tax will be transferred onto electricity for cars in my opinion... (and by that time I hope to be charging by solar!)
I’d also recommend Octopus GO. I moved from OVO, where my E7 rate was almost 10p per unit, so the GO rate of 5p is half what I was paying.Need advice guys, been reading all the posts and not sure which route to take with regards to choosing an energy supplier.
I don’t have a smart or E7 meter at the moment, so whoever I choose will need to install a new meter. My current energy supplier; Shell Energy, won’t install a new one.
I only do about 200 miles a week so which would be more cost effective to me, a smart or E7 meter?
As I do not have the car yet I have no clue about the best way to charge it and that’s why I can’t decide which route to take. Do you recommend topping up the charge on the car every night or would you let it drop to 20% before charging back up to 80/90%?.
Cheers
Steve
Missed this @Roy W. ! Roy has a Referral code if you want it and he would be happy to PM you this!I’d also recommend Octopus GO. I moved from OVO, where my E7 rate was almost 10p per unit, so the GO rate of 5p is half what I was paying.
My split is about 70% off peak, 30% peak, and I manage to do all of my home charging during the four hour GO window. On my LR car I can add over 100 miles of range in the 4 hours.
As for charger, the only drawbacks with the Tesla Wall Connector are
1. It doesn’t qualify for any grants, and
2. It needs an expensive earth leakage breaker adding to conform to the latest electrical regulations.
In that respect you might be better going for a different charger, and get some benefit from a grant.
As for charging, I usually plug mine in if it goes below 60%, and charge up to 90% unless I’m planning a long trip and need 100%.
At that milage I don't think you could make economy 7 work for you unless you have electric heating.Need advice guys, been reading all the posts and not sure which route to take with regards to choosing an energy supplier.
Cheers
Steve
The meter for you is the one that can supply you at a cheap rate when you need it. Some people will find an E7 meter suits them though most people are using smart meters to take advantage of more varied off-peak rates. There are always swings and roundabouts. The Octopus Go EV off peak rate is super cheap at 5p per kWh but as it lasts from 00.30 to 0:430 you do have to make best use of those 4 hours. Fo most people with a home charger that works out just fine for average mileage. You do need a smart meter for Octopus Go .. if you have a SMETS2 or a SMETS1 made by Secure you are all set to go. Octopus will arrange for you to get a meter if you go onto one of their other tariffs meantime and let them know you want to go onto Go. Sometimes this is done quickly, some people have had to wait .. they'll give you an idea.
Plugging in every night, if feasible, is the best approach for several reasons. One is that this is recommended by Tesla and gives the car every opportunity to optimise the battery management. Also if you are plugged in when you switch on the heating in the car 10 minutes before you leave (using the app) the power to heat up will come from the mains and not from your battery ... leaving you more range... you need this in the winter! Another is that you always want your car to be ready in the morning for whatever the day may bring ... plenty of charge onboard. You may well work out that the miles you cover in a week may only look like one charge needed but that presumes you will start some days with a very low charge so may be unable to complete that unexpected extra journey that came up. (The first time you do that all the naysayers will be queuing up to laugh and point!) One of the EV advantages (if you have home charging) is you never really have to think much about "filling up" ... if it's routinely plugged in it's always ready in the morning. (You set the percentage on the car, say 90% that you want it to have.)
