St Charles
Tesla, not TSLA!
I don't know. I was not aware of how to datalog at the time. If it is possible to grab historical logs, I am willing to do so.
4890 without driver. Where does MT list all of the options on the test car? I don't see that, I do see a $130,700 price as tested which is not a stripped down car.
My next 200 might be in here too.
For all I know, and the way it's going right now, all the rest of my posts might be in here.
A new 1600 amp car has done 10.804.
Doesn't mean it can't be done. In going from 1500 to 1600 amps its only a 2% increase in power. Surely a car and driver configured like TRC's that does 10.8 could do 10.9 with only 2% less power.
Yeah, but as you increase the current the voltage sags more. With my pack when I measured voltage and current I got:
1500 amps at 323 volts = 484500 watts
1600 amps at 310 volts = 496000 watts.
496000/484500 = 1.024
The P85DL packs sagged to 305 volts at 1500 amps.
Haven't seen any actual measurements of the 1500 amp voltage on pre-April packs, so can't say.
I just got mine in mid July and it's 1600 amps and 500Kw.Presumably but we have no data. I've asked the guy repeatedly in his youtube videos to use PowerTools to log the KW and so far he hasn't. He *Just* got his car. I'm not so certain that this isn't a V3 battery that we don't know about yet given this time is far far better than the other V2 times.
That's the same as a P85DL. So how could it be that you could expect less performance with a upgraded P85DL vs a new P90DL? It must have been software limited. Has anyone posted actual voltage vs current measurements for a v1 P90DL?
These are just power measurements. With these we have to assume what the current and voltage were. I'd be interested in seeing what the actual current and voltage were. Someone would have had to use a can bus analyzer to get this data.
You don't need to. We know they're 1500 amp batteries making 456KW which makes it a sag to 304 volts.
What??? 1600 / 1500 = 1.067.True which is why the 15.4% increase in current from 1500 to 1600 only results in a 10% increase in power.
The batteries are capable of 1500 amps. The 304 volts assumes they are not limiting the current to cap max power to protect some other component. The decreased sag might still be available, but the power curve they have programmed isn't making use of it which is why I wanted to see how the voltage varied with current.
There have been plenty of CANBUS charts posted of both P85DLs and P90DLV1s.
This is what I was looking for. Do you have any links? Without this information, your condescending A = B * C isn't correct.
Right. This is what I keep asking for.It is if you're assuming the car is making it's maximum current. If you want to know the relationship between voltage and current and less than maximum current, then you'll need CANBUS data to see the breakout before their multiplied together for the detailed REST API response.
Geez....
Well on the bright side, I'll have my first 100 page 2000 post thread!
