NON-Autopilot near collision today
Discussion in 'Model S: Driving Dynamics' started by Carla-C, Jul 14, 2016.
  1. Carla-C
    Carla-C New Member
    Palo Alto, CA
    This is my first post on TMC.
    I have a 2013 85S. I was driving to work 5:30AM today in San Jose, CA. 70mph. No traffic at all. I was in exit lane (long, 1 mile exit ramp.) Someone pulled right next to me. I thought a crash was inevitable. I slammed on the brakes, assume ABS kicked in. Tesla pulled me right towards the wall on my right, shaking and rattling. I was able to FORCE the steering wheel back towards the left to avoid the wall, car again pulled me toward wall, this time at slower speed. Whole thing continued for 8-10 maneuvers. I started a tailspin but I think the ~~~~~~ motion kept me out of a full spin. I was definitely ready for impact with the wall, just wanted to hit at a slower speed, but somehow managed to avoid. Still not sure how. Anybody ever have a similar braking experience? Definitely frazzled. Called tech support to pull data. Any input appreciated.
    thanks!
    Carla Carvalho, Palo Alto, CA
  2. brantse
    brantse Member
    Somerset, PA
    Sounds pretty crazy. Glad you pulled it out without any impact.
  3. techmaven
    techmaven Active Member
    That sounds terrible. Please do have your vehicle's alignment checked. It shouldn't pull hard to one side under heavy braking assuming the road surface is even and smooth. It could be the road that causes the issue too. It should shudder.
    I've always made it a point to test really hard braking once a year or so... go to a really big, empty parking lot and in the rain, slam on the brakes and feel the anti-lock braking kick in.
  4. Garlan Garner
    Garlan Garner Well-Known Member
    Chicagoland
    Wow, a situation where AP is not the blame? I don't believe it.
  5. Cosmacelf
    Cosmacelf Well-Known Member
    San Diego
    Sounds like something is wrong with your braking system. I've had similar experiences with other cars, but not with my Tesla. Under hard braking, it slows and stops dead straight. Have it checked out at the service center.
  6. Cosmacelf
    San Diego
    Also that 2013 85s doesn't have any fancy collision sensors or anything, so it's likely just a fault of the braking system...
  7. trils0n
    trils0n 2013 P85
    SF Bay Area
    Time to get your brakes and alignment checked. Please drive safe until you get everything checked out.
  8. Pdub2015
    Pdub2015 Member
    Wheaton, MD
    Hey Carla-C, glad you made it through that. Good job on avoiding an accident! From what you describe, it does sound like your car's front end is out of alignment, or you may have a braking bias imbalance. Suggest you take your car to get checked out right away.
  9. AWDtsla
    AWDtsla Active Member
    NE
    Regardless of if there is anything wrong with the car, I think you should definitely take a performance driving course. The car is not an appliance.
  10. Boatguy
    Boatguy Member
    SF Bay Area
    The shaking is the anti-lock brakes pulsing and normal, it's what preserved your ability to steer the car. As @techmaven suggested, it's good to experience that under controlled conditions, like a wet parking lot. Crank up the speed, smash the brakes hard and then steer the car to get a feel for what happens. Though you obviously just experienced it!
    In any case, congratulations on maintaining control and avoiding an accident. Well done.
  11. zambono
    zambono Active Member
    DC
    Have the brakes checked , looks like right side is applying force harder so maybe something is not right with the left.
  12. Carla-C
    Carla-C New Member
    Palo Alto, CA
    Thanks for the feedback. I really can't tell if the swerve L --> R--> L was a problem or part of keeping me out of a spin. I didn't even think to have alignment checked, will do so next week. Never had to slam on brakes at 70 mph before.
  13. Pdub2015
    Pdub2015 Member
    Wheaton, MD
    If your front wheels were pointed straight ahead when you "slammed" on the brakes at 70, your car should have tracked straight as it slowed. Pulling to either side is evidence of problem with alignment, brakes, tire inflation or a combination of these.
    However, if your wheels were turned when you did this, well.... totally different story. You said you were in an exit lane, was it straight or curving?
  14. sillydriver
    sillydriver Member
    Middleburg, va
    I assume in addition to hitting the brakes you moved to one side to avoid the car next to you. Is it possible you put a tire off the pavement into a soft shoulder or worse, grass and dirt? Putting a tire off a sharp-edged road into dirt could produce the symptoms you report. If this is what happened I'm sure it was unavoidable due to the other car.
  15. sorka
    sorka Well-Known Member
    Merced, CA
    Right front brake piston is stuck causing little or no braking action on that side.
  16. rogbmw
    rogbmw Member
    Central Florida
    As others have said, if you have never experienced ABS braking, then either take a driving course, or go to a BIG open parking lot on a weekend with no cars and stomp on the brakes. You did not say how old you were. I have taught BMW driving courses in the past, and ABS braking is one of the largest learning curves for people - especially those who have been driving for some time. Pumping the brakes is what most people try to do, but with ABS braking and stability control, it not what you want to do. You want to mash on the brakes and steer the car.
    Glad everything came out ok. As others have said, take the car in for evaluation just to make sure the alignment and brakes are within spec.
