Some of you may have been around long enough to recall the Roadster also had horrible parasitic energy use at first. That took a Martin Eberhard blog post (Roadster uses as much energy sitting still as a refridgerator) rather than a fail in a national paper to get a firmware update to fix.
I wonder if the large surface area of the underfloor battery contributes to the amount of heat lost and replacement needed to maintain the cells within spec?
