ACarneiro
Yes, this is also a good option. I would imagine the cost to implement would depend on what system is installed already, though.A 10kW electric shower will cost you £973.33 to run per year taking 4 x 10-minute showers a day: (10/60) × 10 × .40 × 4 × 365
But... we're meant to be forsaking fossil fuels. A better solution would be an immersion hot-water cylinder that you run between 11:30 pm and 5:30 am (the cheap and environmentally-friendly rate). Heating a 250L tank from 0% to 100% takes around 4h with a 3kW element, costing you £109.50 per year: 4 × .075 × 365
If it’s a combi-boiler then it’ll probably be a rather expensive plumbing job, not to mention that you will also have heat losses from the water cylinder to think about…
