My roof rack was meticulously installed by me using a Matco torque wrench. I had NO issues at all for nearly two years. Then suddenly it cracked out of nowhere. A quick inspection uncovered a few clues as to why this may have suddenly failed. Since the mounts are solid rubber, the corner mount that cracked the roof had loosened up as the rubber mount does age. All the other mounts were loose as well but not as much.
Funny thing was that I had periodically checked the torque from time to time over those two years but found the reading were within specs. I’m thinking the rubber mounts have around a two year lifespan and should be replaced every 24 months or so to assure firm flexibility, NOT OVER FLEXIBILITY, or over compression.
When you drive, the car’s chassis does have torsional twisting flex. If the two sides of the car are bridged by the roof rack, a failing corner mount could flex more than the others thus pinching the glass and cracking it. Bottom line, I will be replacing all four rubber mounts every 2 years or so with new ones, thats after I replace the glass... oooch!
