Hi Mark,I would like to bring my 2013 model S 85 to your shop. My car drive unit replaced by Tesla at 50k miles then after 80 k miles started making milling noise again. How much it will cost me to replaced or fix this drive unit? Please contact me at (949) 566-5044. Than you so much. Mark
The drive unit has to be removed from the car, and partially disassembled to install the drain kit (which involves drilling holes in some of the parts, and other parts need fabrication work done). You have to be extremely careful not to damage the inverter when removing and installing the cover (a used inverter would likely run you $2k+ for a base, and $3k+ for a "sport"). Also, installing the new rotor seal is also a very delicate process, and we usually have to do some amount of resurfacing on the shaft. If the proper procedures aren't followed, you could create a major leak which would require the D.U to be removed again. I'm not sure if my boss would even consider selling the drain kits for people to install themselves as there is just too much room for error without the proper experience...My 2013 p85 model s had the Du replaced in 2020 w/ 47k miles. Now have 62k miles and think this is probably a cheap investment since it's out of warranty. Biggest issue is getting the vehicle to you 400 miles away. Have you considered selling a kit w/ the drains for those willing to DIY out of the area? I have a shop and have access to a lift to perform the R&R of the DU.
What kind of repair would I ask for if I found an early coolant leak this way, by checking the speed sensor? I had mine checked this summer, and there were no signs of coolant on the speed sensor. I'm willing to keep checking regularly, but not sure what could be done to save the DU if a coolant leak is ever found. Thanks in advance for your advice!The cheapest insurance is just to check the speed sensor on a very regular basis for any signs of coolant, and address any issues ASAP.
Your boss sounds just like Tesla lol Who are you to decide what will i do with my carI'm not sure if my boss would even consider selling the drain kits for people to install themselves as there is just too much room for error without the proper experience...
Early detection can save the inverter from destruction. But still would require pulling the drive unit and replacing the sealWhat kind of repair would I ask for if I found an early coolant leak this way, by checking the speed sensor? I had mine checked this summer, and there were no signs of coolant on the speed sensor. I'm willing to keep checking regularly, but not sure what could be done to save the DU if a coolant leak is ever found. Thanks in advance for your advice!
Hi AJ,The drive unit has to be removed from the car, and partially disassembled to install the drain kit (which involves drilling holes in some of the parts, and other parts need fabrication work done). You have to be extremely careful not to damage the inverter when removing and installing the cover (a used inverter would likely run you $2k+ for a base, and $3k+ for a "sport"). Also, installing the new rotor seal is also a very delicate process, and we usually have to do some amount of resurfacing on the shaft. If the proper procedures aren't followed, you could create a major leak which would require the D.U to be removed again. I'm not sure if my boss would even consider selling the drain kits for people to install themselves as there is just too much room for error without the proper experience...
Unfortunately there are people in this world who would blame them for the labour they didn't do. Those whose ambition exceeds their mechanical aptitude. Even after volunteering numerous hours of proper instruction to a customer they have the drive unit fail within the year, and then write on various social media platforms and post negative reviews of the kit claiming it didn't work, telling all don't go to XXXX company, don't use company XXXX's products etc.Your boss sounds just like Tesla lol Who are you to decide what will i do with my car
Never understood this business model, except that someone trying to have a monopoly on certain things...
Sell the kit and let us DIYers do what we do, its not like we gonna blame you for the labor you didn't do, especially considering that you're backed up anyways...
The drive unit would need to be removed from the car to replace the rotor coolant seal at a minimum. If caught early enough, you can mitigate the risk of damaging the rotor bearings, but usually at least the one on the end gets the grease washed out of it and would need to be replaced. If the rotor sealing surface has any pitting or grooves, it would also need to be resurfaced or sleeved to ensure good contact with the new seal.What kind of repair would I ask for if I found an early coolant leak this way, by checking the speed sensor? I had mine checked this summer, and there were no signs of coolant on the speed sensor. I'm willing to keep checking regularly, but not sure what could be done to save the DU if a coolant leak is ever found. Thanks in advance for your advice!
Yes its unfortunate that ppl like that exist n they don't deserve to be on this planet but that could happen even with full drive unit rebuild by the company.Unfortunately there are people in this world who would blame them for the labour they didn't do. Those whose ambition exceeds their mechanical aptitude. Even after volunteering numerous hours of proper instruction to a customer they have the drive unit fail within the year, and then write on various social media platforms and post negative reviews of the kit claiming it didn't work, telling all don't go to XXXX company, don't use company XXXX's products etc.
As an owner is this potential negative reputation and future loss of business worth making $100 for selling a kit? I wouldn't do it.
Also, why do people expect a business to give away their secrets? they absolutely have a right not to give out vital information as the business's knowledge and expertise in a particular field is the reason the business exists in the first place. I enjoy the information @ajbessinger has been sharing with us, but I honestly think his boss may think he has been sharing too much.
And I say this as a proud DIY'er.
There are a few big differences our rebuild vs. a new or remanufactured one from Tesla. For one, we use a triple lip coolant seal, similar to the originals that Tesla used from 2012-2014, and are less likely to wear out prematurely (though the early drive units had issues with bearing noise due to the use of steel rotor bearings). All the newer drive units use a single lip coolant seal, which does not seem to hold up very well... Similarly to what Tesla has been doing since ~2015, we use non-conductive hybrid ceramic rotor bearings, which prevents noise issues from occurring due to internal arcing within the bearing. Basically we tried to take all the best parts from all versions of the LDUs, and try to combine them together to make the most robust possible setup.
Timing wise, seems like like Rev Qs were all rebuilds after 2015.
I would love to know the answer to this. So,So is it true all Rev Qs have single lip coolant seal in your experience?
That's a bit puzzling to me as I received my Rev Q in October of 2017 and the invoice shows it as not remanufactured:
ASY,P-TRAIN,MECH,COMPLETE,RC (1002633-00-Q) Quantity 1
ASY,HV COVER,INVERTER (1003783-00-B) Quantity 1
BRKT, HV CBL TO DRV INV, 2MM THK, STL (1019545-00-A) Quantity 1
SCR,M6-1.0X12,PH,TORX,STL,SEMS,PATCH (1011427-00-B) Quantity 1
My 2013 MS85 2nd and 3rd DU invoice shows
3/4/2015 25735 miles
Concern: Please install S/O drive unit to address "clunk" from rear of vehicle on load shifts (not rectified with installation of shims)
DRIVE UNIT - BASE WITH SHIMS - REMANUFACTURED (1025276-00-K)
3/6/2017 39891 miles
ASY.P - TRAIN,RMN,,MDLS,BASE,CMC,HS,FA2+(1025276-00-A)
So I got reman 2x and RevQ in 2017 which sounds like when everyone got them.
$4800 for a revision-T unit.
There are both reman and new T units in the sport or performance size. Maybe @ajbessinger could let us know if the reman T units were once new T units, or revised Q units?
