Not shown on this screen but 60-0 was 106.85 feet for this stop.
Not shown on this screen but 60-0 was 106.85 feet for this stop. View attachment 347906
Ha. That stop was also with low regen on. If you add the 0.2g of regen it would have stopped about 20 feet shorter, way better than your P3D+!You’re going to wear out your brakes and your tires! I guess it will balance the tire wear by scrubbing off the fronts.
Yes but 235/45 for the MXM4s of course. I suspect that the additional width doesn't help much with braking distance. Maybe I'll be able to test back to back with the 235 width PS4S at some point.What are the two tire sizes we are comparing?
235/40-18 MXM4 on 18X8.5" wheels Tread width 8.5" (Tire Rack)
265/40-18 MP4S on 18X9.5" wheels Tread width 9.4" (Tire Rack)
I wonder how much tire pressure would effect the performance. I wonder with wider tires, if you need to run lower psi to get more grip.
There should be a sweet spot for maximum grip because too much pressure you lose surface area as the tire pillows out. Too little it'll start cupping or something of the sort. The best grip would be where you can maximize tire road contact area.
What's a bit weird is the lack of hard empirical research about this sweet spot across brands of performance and track tire. You'd think we'd know this value for tires, but it seems this info is hard to find, and mostly it's all anecdotal. And of course the other problem is that those best performance pressures almost always result in an undesirably exaggerated crown wear pattern.
Another interesting issue here is low rolling resistance, which of course is many tread and sidewall variables but where higher pressures are a cheap way to get there without making a lot of other changes that might impact traction negatively. The Michelin Pilot Sport 4S, arguably the best street performance tire out there, is set to run a 42 lbs by Telsa. I suspect that Michelin made some changes to the Super Sport to mitigate and even out crown wear at higher pressures, so that the 4S could be run at those pressures chronically and still wear fairly evenly. Don't know that for fact, but it's my best guess, as no previous Super Sport was recommended to be run chronically at those pressures.
max performance sits at an intersection between declining contact patch area vs. increasing contact patch stability.
What I'd love to see a Stealth P3D versus a P3D+. How much of a difference is those MXM4s vs. PS4S tires.
So what are the implications of this for chalking tires? Do you actually want to see a bit more chalk left on the outside, or does that all go out because hard cornering should move that back towards wanting to see even chalk removal across the tire because you're pushing it hard enough to deform anyway so you want it to deform to "normal"?Not quite, as road contact patch steadily increases as TP declines. One of the great paradoxes (or seeming paradoxes anyway) is 'why doesn't lower tire pressure make for better cornering and braking' given that your contact patch area (which obviously impacts max lateral and vertical loads before breaking the traction envelope) is mostly inversely proportional to your tire pressure?? Higher pressures mean lower contact patch area? How can that make the tire perform better?? Seems a bit weird when you think about it in those terms, but it turns out that the contact patch stability (resistance to squirm/bunching up/rolling over) under extreme load is roughly proportional to TP, so max performance sits at an intersection between declining contact patch area vs. increasing contact patch stability. For a lot of tires that's somewhere in the high 30s to low 40s lbs territory, but most tires probably in the 40s if the tire is not under-loaded. On my IS350, I actually dropped TP on the rears a bit, as the tire (255/40-18) was so lightly loaded relative to the fronts that the rear would tend to break free in corners at higher pressures.
