In the most simple terms more current requires more copper. Handling voltage is the job of the insulation.I just put the information of electrical physics here, that wire gauge ties to current and not voltage, and then people started trying to argue with reality. It's not about me or you.
Bolt EUV has a dual-voltage adapter with 5-15 and 14-50 (32A).Tesla is not the only one playing these games with a "mobile connector". I've seen Leafs, Bolts, and similar, all of which can certainly plug into Level 1, NEMA5-15 (that being the most common wall socket in North America), and probably NEMA6-50/NEMA14-50, those being popular at places like RV camp grounds. Having never owned a non-Tesla BEV, I'm less certain what-all adapter set a, say, Chevy Bolt comes with, but there it is.
We're saying the same thing, so no arguments. The NEC has a clause for "steady, heavy loads" on a circuit, which means, for all intents and purposes, a BEV. The clause states that One Shall Not Draw More Than 80% Of The Circuit Rating. So, a NEMA5-15 is only good for 12A, a NEMA5-20 is only good for 16A, and so on.Bolt EUV has a dual-voltage adapter with 5-15 and 14-50 (32A).
Bolt hatchback is 5-15 but has the dual voltage as an option (+$295, I think).
All the other dual-voltage I know of that you can get directly with the car are 5-15 + 14-50. Some EVs deliberately limit 120V to 12A on board.
The mobile connector is 32A limited even though new Bolts have a 48A onboard charger standard*.
As a rule I think these mobile connectors are limited to 32A because if you see a 14-50 socket it's only guaranteed to have a 40A breaker. There's no 40A socket.
* Yes, the Bolt is a good EV for driving within range. Just imagine if they can make it a Boltium and up the DCFC without adding much cost.
I don't have the numbers right in front of me, but I did check after my relative bought a Bolt. It does do DCFC. Unfortunately, it's not a fast rate, I think 50 kW? As compared to a Tesla that can pull 250 kW, albeit for a short time only.If I had known the Bolt was not able to level 3 charge, I had forgotten it. That's a significant limitation. It is seriously lame to provide level 1 charging capability, but not level 2.
I assume EUV is a model identifier?
Yes, it's a mini SUV (sport utility vehicle) version.I assume EUV is a model identifier?
The Level 1/Level 2 stuff is AC and standard. Not sure what the fastest L2 charge rate is on the car.
AC means alternating current and is how city power comes. (Unless, I suppose, there's some corner of NYC or something that still had DC 120V hanging around somewhere.)What does that mean, "The Level 1/Level 2 stuff is AC and standard"???
Pretty much every EV made (a) has batteries, (b) the batteries are DC, and (c) there's rectifiers in the car that accept 120 VAC (L1) or 208/240 VAC (L2), convert the AC to DC, then play some voltage level follies so the batteries can be charged.
Pretty much every BEV comes with something like a Tesla Mobile Connector
that can be plugged into a 120 VAC socket, for sure, and may have additional follies for 208/240 VAC sockets. In addition, I'm not aware of any BEV that does not come with a J1772 port or adapter. J1772's are built for 208/240 charging, but, again, as far as I know, the only way to get a J1772 cable and plug is by using a Wall Connector or equivalent, commercial or otherwise.
Since all BEVs pretty much come with L1 (NEMA5-15/20) or J1772 (208/240), the question is what an enlightened parking lot owner would do. If said parking lot owner is doing long term parking, L1 makes the most economic sense for everybody, since NEMA5-15/20 sockets and hardware is cheap.
Just quibbling, here.Wow! Maybe you should understand the question before you write a dissertation.
What do you mean by calling it "standard"? What part of this conversation has been about non-standard electrical connections???
You mean every BEV other than a Tesla? Teslas no longer come standard with a mobile connector cable.
L1 EVSE, yes, I agree.
So: I understand the meaning of the words, Electrical Vehicle Supply Equipment.
And if I came across such an acronym, what would come to mind immediately would be, say, a Juicebox. A Tesla Wall Connector. A Supercharger. EV-Go DCFC. Similar from Chargepoint or any other number of vendors. All of those being completely dedicated to charging electric vehicles.
It's Equipment. It's for Electric Vehicles. And it's used to Supply power to the electric vehicle.
Sure, I get all that. But say one has a large parking garage and there's a NEMA5-15 socket, say, next to every stall. OK.... That's pretty much the same socket I've got all over the place in my house. TV sets, lamps, radios, computer gear, refrigerators, microwaves, garbage disposals, alarm clocks. Um. Plus four or so scattered around the outside of the house with plastic covers and such so, I guess, I can run weed whackers, lawn edgers, and the like.
And, like.. If I park at the plaza downtown, like as not, there's a 120 VAC NEMA5-15 socket at the base of some of the lamp posts; guess the city puts them up so people can charge their cell phones, or maybe so city employees with a leaf blower can do their thing.
Now, I could haul out my Tesla Mobile Connector and plug into any of them. Easier with the one in the garage, of course, but I have a heavy duty extension cord and could even connect the car to the NEMA5-15 out on the front porch.
But calling those common-as-dirt NEMA5-15 sockets, "EVSE" kind of stretches the definition, don't you think? Sure, calling the Tesla Mobile Connector (and the equivalent with other BEVs) a bit of EVSE hardware.. sure, I guess. Bit of cable, funny sockets, electronics built in, fits the idea.
But it's the use of the term. Something like a Juicebox or Chargepoint station fits the definition of "EVSE" like a glove. A bog-standard, non-electronic, 120, 208, or 240 VAC socket.. not so much.
Admittedly, some long-term parking guy putting in a zillion NEMA5-15 sockets in a parking garage kind of fuzzes the definition a bit, since the purpose is to charge electric vehicles. But there's no electronics in those sockets (plus or minus a GFCI breaker somewhere). So a "L1 EVSE" seems to not make a whole bunch of sense.
Pedantic, I know. But words have meanings.
A coupé (2 door), sedan (4 door), truck, minivan, van or SUV. Chevy calls it a small crossover SUV; slightly bigger than the hatchback Bolt but smaller than a regular-sized SUV. Google it.As opposed to what?
Weird. Maybe if you've only had Teslas, that's your POV. Virtually every highway legal non-Tesla consumer BEV/PHEV for years, since Dec 2010 has references to level 1 and level 2 J1772 AC charging. Most of them for ages ONLY shipped with L1 120 volt EVSEs (NEMA 5-15 to J1772), usually 12 amps. I'm on my 4th BEV (two were the same model), all of them came ONLY with an L1 120 volt 12 amps EVSE.First, stop calling it Level 1, no one know what you are talking about.
Just call it a standard 120V plug like is on the wall.
The issue is that there can be electrical limits for the facility in question (e.g. max amps or kW that can be drawn). Most vehicles charging via L1 will pull no more than 1.44 kW (120 volts * 12 amps). GM vehicles will default to 8 amps (8 amps * 120 volts = 960 watts) unless you override it.Level 1 versus Level 2:
This is just the voltage level difference between 120V or 240V. If receptacles were being installed, it's the same wire, and it's about the same price for the breakers and outlets. There's really no cost difference at all between Level 1 or Level 2.
Some are adjustable, including Tesla's wall connector, Juicebox and units from Autel (see page 33 of the PDF at https://cdn.shopify.com/s/files/1/0...maxicharger-home-user-manual.pdf?v=1659467651). Unfortunately, it seems after Clipper Creek was bought by Enphase, their catalog was slimmed down a ton.Not sure what you mean here. Are you telling me you've seen 15A, 240V EVSE? I think we are crossing over into absurd points.
He has a fair point though. If you want skeptical property owners to be receptive of installing more L1 options, to stop using terms they don't understand (and don't want to understand) is a good first step. If you tell them it's just a 120V socket (or if installing a J1772 that it's the same power), they immediately understand what it means. If you say L1 they will likely gloss over.Weird. Maybe if you've only had Teslas, that's your POV. Virtually every highway legal non-Tesla consumer BEV/PHEV for years, since Dec 2010 has references to level 1 and level 2 J1772 AC charging. Most of them for ages ONLY shipped with L1 120 volt EVSEs (NEMA 5-15 to J1772), usually 12 amps. I'm on my 4th BEV (two were the same model), all of them came ONLY with an L1 120 volt 12 amps EVSE.
Due to slow charging times, many BEV drivers want to get an L2 EVSE installed at home. Many PHEVs don't have large batteries anyway so replenishing their small packs at L1 speeds is no big deal.
120 volt plug on the wall isn't the only means of L1 charging.
https://web.archive.org/web/20130823034430/http://www.l1powerpost.com/ even had its own domain and product page before they branched to selling both L1 and L2 versions: Products | PowerPost EVSE.
