There had been some vigorous debate about GM's decision to market the Volt using the term "EREV" rather than the traditional "Plug-in Hybrid" nomenclature that groups like the SAE classify it as.
I'm in the "It's a hybrid" camp. The argument for the specific "EREV" moniker often includes the point that the gas engine is mechanically engaged in to the drivetrain rarely under specific circumstances...
So, what's the consensus here? Is the "EREV" moniker finally dead?
Sigh. This again? That GreenCarReports article was terrible in content but great for inspiring page hits. If you are here reading this thread then you might as well read through the 200+ comments on that article.
The bottom line, as I've explained at this site before, is that GM created or at least popularized the term Extended Range Electric Vehicle (EREV) and promoted its definition in an SAE technical paper written in the same year that the Volt concept was revealed and the Volt was approved for production engineering in 2007. GM's definition of EREV has nothing whatsoever to do with how the range extender is or is not mechanically geared to the wheels. GM's definition is all about the conditions under which an EREV stays in EV mode. GM's definition says absolutely nothing about how the car operates after the range extender starts up.
According to GM's definition, an EREV starts off in EV mode on a recharged battery and stays in EV mode while usable charge remains regardless of torque demand or vehicle speed. It also requires the vehicle to be freeway capable as defined by a California Air Resources Board document that categorized different plugin vehicle types (in other words, it can't be a Neighborhood Electric Vehicle or a golf cart).
That's it. There are no other EREV requirements. So, for example, the Chevy Volt, Cadillac ELR, and the BMW i3 clearly fit the EREV criteria. A Ford CMAX or Fusion Energi would fit the criteria if placed persistently in their EVNow mode. The new Cadillac CT6 plugin hybrid would not be an EREV because it blends in the gas engine under high torque demand in order to deliver 250 kW of power while using a 2nd generation Volt battery capable of only about 120 kW.
Finally, the characterization that the original Volt uses a mechanical path from the engine to the wheels "rarely under specific circumstances" is misleading. The original Volt uses series mode under 35-40 mph and during high torque demand. Otherwise, at speeds above 40 mph, it is far more likely to be in its power-split mode with a mechanical path when the gas engine is running than in its series mode. According to the GM SAE paper that discusses the original Volt transmission, the Volt is in power-split mode about 3.6 times as often as it is in series mode during the US06 EPA highway test cycle.
Thankfully, at least this aspect of the misinformation about the Volt is going away since the next generation Volt no longer has any "pure" series mode -- it's range extender always has a mechanical path to the wheels whenever it is running. Yet it's an EREV.
I co-authored the first (and still the only) detailed explanation of the 2nd generation Volt transmission two months ago. This same transmission with minor modifications is also used in the 2016 Malibu hybrid to get 47 mpg with a 1.8L engine. The article also gives a brief overview and illustration of the original Volt transmission. You can find the article here:
Gen 2 Volt Transmission Operating Modes Explained
