JRP3
Hyperactive Member
I guess Tesla might as well add an ICE and reduce the pack size, since it would still be an EV, no difference. Stop building superchargers too, since "EV's" don't need to be charged if you can just put gasoline in them.
Sure, but I expect better of the moderators here. I correctly point out that a hybrid is a hybrid, and the post gets moved to the inappropriately named "Dogma" thread?
There is no reason to argue what is and what isn't an EV outside this thread.
Car and driver calls the i8 and i3 a series hybrid to distinguish from the volt As a parallel hybrid. Distinction is if one can route power straight from ice to wheels. I think this is most accurate way so far to describe. None are EVs
The Volt is a bit more complex and can operate in both series and parallel hybrid modes. Still a hybrid of course.
I think it's pretty obvious, if it's got a gas engine it isn't an EV, it's either an ICE or a hybrid. But the manufacturers invented the term extended range electric vehicle specifically for the purpose of causing confusion, and apparently it has worked, you only have to read this very thread to see how many people buy the marketing speak.
Since you seem to think this is black and white, I'm curious where you think the line is here.
The Model S as built is obviously an EV, right?
If you put a portable generator in the back to move it to another location, does that make the Model S a hybrid?
What if you bolt the generator in, but never use it to charge the car?
If you use the portable generator to charge the car while parked, does that make it a hybrid?
What if you override the car's code so the generator temporarily placed in the back can charge the car while it is driving?
Walter
In case anyone cares, according to the Society of Automotive Engineers' definition of a hybrid, the last modification is required to make the car a hybrid.
GSP
The January 12, 2015 edition of Automotive News has an interview of Ian Robertson, a BMW marketing exec, on pages 29-30, including the following question:
Is it correct to call an i3 with a range extender a plug-in hybrid?
"It is not. It is a battery-powered vehicle where only the electric motor powers the wheels." :scared:
This guy is obviously in marketing. If he were an engineer he should be fired for incompetence.
GSP
He is of course technically incorrect.The January 12, 2015 edition of Automotive News has an interview of Ian Robertson, a BMW marketing exec, on pages 29-30, including the following question:
GSP
That's exactly what we would call it before the whole "EREV" thing GM invented to muddy the waters (I wonder how history would be different if the Volt remained as a series PHEV and there was no need to invent the "EREV" term). Series PHEV is a clear-cut unambiguous engineering based term.Plugin Series hybrid.
...under California law, the BMW i3 with REx is the first of a new category of plug-in electric cars, known as a BEVx....
... California zero-emission vehicle regulations permit a BEVx to count toward a carmaker's "ZEV gold credits"--effectively, the number of zero-emission vehicles it sells (even though the i3 REx may produce tailpipe emissions in range-extending mode)...
...Under all other regulations, though, the BEVx designation simply doesn't matter. A regular BMW i3 is a fully-electric car, and a BMW i3 REx is deemed a plug-in hybrid for any other incentive program.That puts the range-extended i3 in the same category for California's plug-in purchase rebate and its carpool-lane access as the California-spec Chevrolet Volt, Toyota Prius Plug-In Hybrid, and other cars that plug in but also have combustion engines...
