The car navigator told you to leave the current charger with 5% estimated range remaining upon reaching the next charger or destination??That's just the bloody car navigator that I'm already using!!!
Is he, or is he implying that when he said "use the trip planner" he meant "follow its directions"? I mean, it's been a while since I've used it, but I THINK the trip planner function includes suggestions on when to continue you trip.You are distorting the facts.... again.
People seem to be willfully ignoring how this played out. When he got to a Supercharger that was farther along the route, the target arrival estimate was 12%. It was "following the Trip Planner's directions", because it would not suggest needing to stop at that Supercharger when there is already a 12% margin.Is he, or is he implying that when he said "use the trip planner" he meant "follow its directions"? I mean, it's been a while since I've used it, but I THINK the trip planner function includes suggestions on when to continue you trip.
Actually, if you pay attention to usernames as you review this thread, you will notice that I have pointed this out several times (and most of those times, you have hit like). However, if you follow the quotes back on what I just responded to, and assuming my memory is serving me correctly, gnuarm complained about not having a good tool, and tes-s pointed out a tool gnuarm might not be using (Trip Planner). The point of my response to gnuarm here was that using navigation while making your own decisions (as he at least fairly reasonably did) and strictly following trip planner's advice are not the same thing.People seem to be willfully ignoring how this played out. When he got to a Supercharger that was farther along the route, the target arrival estimate was 12%. It was "following the Trip Planner's directions", because it would not suggest needing to stop at that Supercharger when there is already a 12% margin.
You implied that he did not follow the Trip Planner's directions, but it did not recommend him to stop there for charging. That's following its directions.Actually, if you pay attention to usernames as you review this thread, you will notice that I have pointed this out several times (and most of those times, you have hit like). However, if you follow the quotes back on what I just responded to, and assuming my memory is serving me correctly, gnuarm complained about not having a good tool, and tes-s pointed out a tool gnuarm might not be using (Trip Planner). The point of my response to gnuarm here was that using navigation while making your own decisions (as he at least fairly reasonably did) and strictly following trip planner's advice are not the same thing.
Tes-s implied that he didn't follow its directions, but I see your point. While he explicitly didn't at the start of the story, implicitly following them later on negates that point regardless of whether or not the previous behavior would have made a difference and perhaps even implies a problem with Trip Planner, making the title of the thread even more accurate.You implied that he did not follow the Trip Planner's directions, but it did not recommend him to stop there for charging. That's following its directions.
In what way?You are distorting the facts.... again.
He has implied that the answer to 1 is yes. As outlined above, the answer to 2 is irrelevant, because Trip Planner should have routed to an additional supercharger if necessary. Regarding 3, have you ever been told to slow down to reach your destination when you were going 35 mph? I believe he has already implied that he did not, but I'm not confident he should have. I've seen "drive 45 mph to reach your destination" once, but nothing lower than that. I'm not sure how low the estimated range at destination has to be before you got those warnings, but I'm pretty sure that it's below 10%, in which case, nothing before the point when it was estimating 12% is really relevant. I think the only legitimate question that might not already be implicitly or explicitly answered is, "did you ignore directions leading you to another supercharger?"In what way?
Are you using the Tesla Trip Planner feature (and following its guidance), or are you making your own charging decisions? It guides you to your destination via superchargers as necessary - including telling you when you have sufficient charge to leave the current charger and reach your destination.
So let's be very careful about exactly what the facts are so there is no distortion:
1. Did you have Trip Planner turned on?
2. When you left the first charger with 5% estimated range on arrival, did Trip Planner inform you there was sufficient charge to reach the next charger/destination?
3. Did you get any sort of message when your estimated range on arrival at destination dropped below 0%?
My experience has been that when the nav is worried you will not make it to the destination shown in the nav, it gives all sorts of warnings to slow down, and eventually says charging needed to reach destination.
The estimated remaining charge did drop as I drove on the secondary roads and I drove at the speed limit or for part of the way below the speed limit because the car didn't know what it was and wouldn't let me auto pilot above 35. lol That was a short stretch, about 6 miles. By the time I reached the highway I had lost about 3% of the arrival charge estimate.
Lots of implications. Looking for some direct answers so there is no guessing or "distortions".He has implied that
One conclusion here is that for whatever reason the energy consumption estimation is inaccurate for this "secondary roads" section of the trip and the difference is about 3% of battery capacity.
For the larger drop on your initial trip I have a theory which is just a wild guess:
In another thread you mentioned that the car got a software update recently.
I assume this update has affected the BMS and there is a chance that the "current total battery capacity" value got somehow reset to a default value (maybe the capacity of a new battery) or the new software version has different curves for estimating the total battery capacity.
The total battery capacity measurement gets more and more accurate as the SoC drops further and further. Saying it in a different way estimating the battery capacity based on a 90% to 60% discharge has a larger error than estimating the battery capacity based on a 90% to 30% discharge.
So at the start of the trip your car thought you have 100% capacity. In the first part of the trip since the SoC was still higher the estimator didn't see any deviation from its original thought. But once the car reached lower SoC the BMS realized the difference and modified the "total battery capacity" value to something like 93%. And modified the range estimation accordingly. Plus there was a loss of additional 3% due to the energy consumption estimation error for the secondary roads.
On your second trip the car already had the updated "total battery capacity", so you didn't experience similar issues.
Exactly!! Some can, and some can't. Just ask the Lion Air crew and third pilot that was in the cockpit. Not the crew that crashed - the crew that flew it the day before.A bit like flying a 737 MAX 8.
He said it told him to turn around. If that means it was directing him past or away from the supercharger and changed its mind, then it would be even more of a failure. However, multiple trips have been discussed, some of which involve taking an alternative route, so I'm not going to re-read all 5 threads to confirm whether or not that is possibly what happened.So Trip Planner told you to stop at a supercharger along the way, you decided not to, and this is a "Range Failure"??
