From what I've read, the least impact on the battery is moderate depth of discharges in the middle of the battery capacity. So a 20% depth of discharge from 60% to 40% would have the least overall impact on the battery (versus 100-80 or 20-0 for instance). Only LFP's need to go to 100 for the calibration, I don't believe the NCA's do.
That is not correct. That is a very common forum truth but not correct. The research show us how things really work. Most research draw the correct conclusions, but there are some resesrch reports that show the correct values but they draw faulty conclusions(most often because the test setup was not very good).
If we start with LFP, modern LFP are not sensitive to the depth of discharge and will do
very many full cycles(charge to 100% and discharge to 0%). For a car with shorter range that need to use a higher deopth of discharge(DoD), the LFP is a good choise. They use more space and is heavier so its not possible to use LFP in a long range car.
For NCA and NMC, they are affected by the depth of discharge. They also are affected by the SOC where the cycle is placed.
The lower the cycle is placed, the less wear.
This means using a 10% cycle causes least wear at 10% to 0%.
Also, the smaller the cycle(DoD), the less is the wear.
One research report used NCA and cycled the batteries 10% DoD around both 30% (35-25%) and 70%(75-65%). The number of cycles was 6000, which is 600 Equivalent Full Cycles).
The cells cycled around 70% lost 10% capacity.
The cells cycled around 30% lost 2.5% capacity.
This is from one research report, LMO/NMC cells. The reason I select these pictures is that it is easy to se the connection between DoD and wear. It should be clear that low SOC is the best. Its also clear that large cycles wear much more.
Recommended long term storage values are at 50% charge which leads me to believe 1/2 full is the absolute least impactful on the battery so basically increasing out from there for whatever daily range you need would seem to make sense.
No, that is not right. Where do you find a recommendation to store at 50%?
The lower the SOC, the lower the wear for long time storage.
This picture show the long term effects of storage, High SOC and or High temperature is worse. The lowest degradation happens at very low SOC. There is a lot of research showing the same. There are no real exceptions from this picture.
High quality chargers for lithium batteries (like for hobby use of lithium batteries) have a storage function that charges or discharges the battery to a specific voltage. This is around 50%. But the selected value is chosen to both allow for long time storage and self discharge and also to reduce the time to chsrge the battery to 100% before use. That storage level is not set to reduce the degradation to the lowest level. But it is below the clear step we see in calendar aging around 55 to 70% depending on the chemistry type.
That's kind of my dilemma with choosing between the AWD and RWD (NCA vs LFP).
You only need to select what range you need. Tesla have already made the choise for you.
-Shorter range need large cycles(bid DoD) and there LFP is better.
-Longer range is not possible with LFP( these cannot be fitted into a model 3 because of the limited space). NCA (and NMC in Europe) is the only option.
Calendar aging cause the biggest degradation with both NCA, NMC and LFP.
If you would like to reduce the Calendar aging it is possible by having the SOC low when the SOC do nit need to be high.
Charge shortly before the trip, and leave it with low SOC overnight until the charging need to be started.
