90% of new ceiling.Question. My 2018 LR used to get 310 on a full charge. Now because of degradation it's in the high 290s. My question is, if I daily charge to 90%, should that be 90% of the original ceiling (310), or 90% of my new ceiling (around 298)?
And tires - and alignment! EVs are sensitive to tires and alignment - put the wrong tires on the car and efficiency will take a big hit 10-15% is not unusual!No, that is definitely not it. Probably just due to changing conditions and capacity loss. (Though the range calculator did hide the first 2% of loss on your vehicle.)
When you say your full range “hasn’t changed much,” that also has to be quantified. You should have started with around 310. Now you are at 290. Did you charge to 100% on prior trips? That would make a 35-mile difference, 310 vs 275.
That plus wet roads, a bit of breeze, a little heating of the cabin, air temp, etc. -many factors can make a big difference.
FWIW my '18 Model 3 is about the same in the same climate.I have about 9-10% capacity loss.
Smaller wheels are great for extending range!This is the wife's new work car, so range is important. Probably going to swap out the 21" Uberturbines for some 19" Gemini's to get her an extra 30 miles or so per charge.
My experience with the Crossclimate 2s is that you will get a significant hit in range at highway speeds - about 10% and it gets worse the faster you go. They tread pattern is pretty knobby and I suspect they have high wind resistance more than high rolling resistance.Don’t track the latest hotness. Sorry. Crossclimate 2 for versatility but will not have low RR. Could look at Pilotsport EV. Not sure sizes available. Check Model Y forum I guess.
Note that I dont believe the actual distance I could drive has changed at all, nor have I done the battery calculation to see what that says.
While true in general under standardized conditions, can’t you extract more energy from a battery at warmer temps? (This is a question, not rhetorical.)Thats right, increased range means the BMS thinks the capacity is higher. The real range will not increase as the battery capacity in real life only goes one way = down.
A (really) cold battery wont be able to deliver all energy. Thats the snow flake (cell temp about freezing or colder). But the energy comes back when the battery warms.While true in general under standardized conditions, can’t you extract more energy from a battery at warmer temps? (This is a question, not rhetorical.)
That being said, no idea how Tesla accounts for small fluctuations like this, if at all. (Of course at low temps they make the available energy smaller and make that clear with the snowflake and whatnot.)
I mean, I know that doesn’t technically mean the capacity has actually increased. But if available energy is higher…
Ok...here is a variation of my theory....first take the energy graph, and find the value of the solid horizontal line (do this by driving until you can get the dotted line to cross the solid line and read the Wh/mile)...then drive until the range on the energy graph equals the range on the battery icon. Read the Wh/mile.
Yes, you are wrong.Am I wrong
Those numbers will take me a month to digest...Yes, you are wrong.
That ratio will be equal to x / (x+5 Wh/mi) where x is in Wh/mi. For my car x is 245Wh/mi.
Will have nothing to do with % remaining in battery.
(Projected Range * Recent Wh/mi) / Battery "Range" = Vehicle Charging Constant
So if Projected Range (mi) = Battery Range (rmi), then Recent Wh/mi = Vehicle Charging Constant (Wh/rmi).
QED.
Ok Vegas guy here..back again for questions to make us think.
2022 MYP with 7500mi. These days 50% SoC gives me 134mi. Battery indicator is always set to % and never miles.
Planning weekend roadtrip to Disney in CA this Sat AM. I think we concluded from a few months ago that my BMS is miscalibrated. My 12% degradation cant be real. My max charge has been always to 50% SoC at planned AM departure since week 3 of owning car. 7 Supercharging sessions in life.
Two questions:
1. Since I plan to Tesla level 2 charge at home to 95% (maybe 100%?) before I depart, anything special I should do here to get some good top end BMS calibration data. Thinking at least have it sit at this charge for a few hours.
I think it definitely could. At least part of it is real so your battery certainly has less capacity than it did when you last made the trip.Could miscalibration impact my actual driving range when I get to the lower SoC on the drive?
When I drove to this supercharger only one time from my home, I went from 100% to 10% at arrival and shitting bricks in the desert the last 30 miles driving below speed limit. Its 185 miles to that supercharger. Strong 20mph headwind, elevation, and AC impacted range with speed around 72mph.
Run some simulations in ABRP, to test some of your ideas. If the goal is to make Hesperia for coffee and to top up for extra charge around Anaheim, why not just make 2 stops, the first stop being a short one, that'll allow you to start with a lower charge. Seems like less risk and worry if you just plan on 2 stops.Ok Vegas guy here..back again for questions to make us think.
Two questions:
2. Could miscalibration impact my actual driving range when I get to the lower SoC on the drive? There is a Supercharger on the way that has a Starbucks that I have only been to once but prefer to stop at since I can top up nicely there and even avoid charging again around disney for few nights before driving back home. When I drove to this supercharger only one time from my home, I went from 100% to 10% at arrival and shitting bricks in the desert the last 30 miles driving below speed limit. Its 185 miles to that supercharger. Strong 20mph headwind, elevation, and AC impacted range with speed around 72mph. My miscalibration is worse now from that time (was ~2000mi odometer). Will my current worse miscalibration hurt my arrival SoC/batt available reading and making it seem lower that it may be? Could I actually be at a higher available battery then the indicated 10%? (And I know I can add a super quick earlier charging stop but I feel the car should be able to handle this one stopper without making me uncomfortable.)
Surely your are correct - I agree, but the problem (at least from my car's data) is that the range as shown on the TeslaFi plot is not the best one to determine range based on real capacity, for example as illustrated by @AAKEE's post #5309.At some point shouldn't TeslaFi use a Best Fit line for its fleet average? That sudden drop at 46k has to be due to lack of datapoints.
How has it been babied ? (I did miss that part earlier in the thread if it was posted.)10.6% degradation for a very babied battery. Hope actual is half.
