By babied, I mean I always setup scheduled departure charge to charge up to 50% right before departure at around 8am since I had the car in April 2022. 4 road trips from Vegas to CA with associated supercharging. 90-100% SoC when leaving house for those.
On the trip to Disney few days back, charging to 100% before leaving home only got 271miles. Lined up with where I thought since 50% was at 135miles and rough math gave the same close 270 expected for 100%.
Unfortunately the pics I took were not of the trip meter page but the energy chart page. Misunderstanding on my part.
I also did not end up going to Hesperia because my daughter needed to go to restroom so I ended up charging at Yermo (Eddies) instead. I have a 5 and 3 year old so pitstops are necessity whether gas or electric. With electric those pitstops turn into opportunities lol.
I will say new calcs from battery indicator miles and SoC show that something has recalibrated in thr direction of goodness. Math for 100% says I will be at 278 now. Dont plan to go to 100% again until maybe cooler temps and road trip. That puts it at 8.2% degradation instead of 12%. Will try again next road trip.
You are the only one who can answer the degradation question and whether it is real. You have access to the best estimate in the world of your car’s capacity. My car seems accurate within a percent or so.
Mostly downhill run (6300 feet), so a lot of regen. No stopping at all.
291rmi at 100%, so that is 71.3kWh, 68.1kWh usable. (245Wh/rmi, 234Wh/displayed rmi for my car - your Model Y and 3 are different,but trivial to determine - for a
degraded car, just charge to 100%, take ProjRang*RecentEfficiency/(rmi@100%) - does not work for a new car though.)
263mi at 225Wh/mi, 59.2kWh, left me at 35rmi after starting at 291rmi.
So that’s (291rmi-35rmi)*234Wh/rmi = 59.9kWh.
So within about 1%. Obviously could be rounding errors which could contribute to that error.
So anyway just do the same, end of story really. No one here can tell you - but you can definitely determine what is happening with your vehicle.
Beefalo! (Not bison.)
I’d be surprised if your car was more than 3 percent off on its estimate on such a test.
