For those guys plugging the car every day, have you tried charging to 100%, turning sentry/summon on demand/overheat protection/etc off, and then letting battery discharge to 30% or so over a few days, so the SOC is reported overnight at different SOCs? That supposedly 'recalibrates' the algorithm, for what I've read. Then charge back to 80% max. It'd be best to do that every 3 months or so. But let's hear from an expert like AlanSubie, and see what he says .
Got an ODB2 adapter finally, and plugged Scan My Tesla.
I have a July-2019 built model 3 performance stealth, delivered in Australia early September 2019.
I had reported concerns to Tesla back in December, after TeslaFi reported a sudden drop in November (from 4% degradation to 8%). Tesla analysed the log and determined a faulty 12V batteries that prevented the car from going into deep sleep mode and the BMS to do its work.
They replaced the battery, told me to charge to 100% and down to < 20% a couple of times to recalibrate the BMS.
They found that the degradation was 7.8% and was within specs.
Since the range reported has continued to drop.
Now it shows a nominal full pack of 69.7kWh (from 77.8kWh new); a 10.4% degradation after just 15 months and 14,700km (9160 miles); 66 charge cycle
What worries the most, is that it steadily goes down after each recharge.
I did to the 90 - 20% over January as discussed in that other thread; with no improvement.
What do you guys think?
Nothing to worry about?
*sugar* pack. A lot of people think it had something to do with the 12V battery failure which may have disabled the BMS for a month or so. I'm not so sure about that...
oh, you calculate the battery degradation from the "Full pack when new" figure ; mine shows 451km now. Originally it was 499km, which is "only" 9.6% degradation.I'm also down to 45x km (like 8-9% degradation) with 30k km on the clock on my stealth.
That was the explanation given by Tesla and was the first time I had heard about it.
Apparently prior mid-October, the software was draining the 12V battery too much, causing premature wear.
My original delivery had been delayed by 10 days already due to a dead 12V batteries, and when the mobile technician came to change my 12V battery, the old one had a build date of October 2019 ; which leads me to believe that in all this car has seen 4 12V batteries since it was built.
451gradation which is very real.
how many km do you see at 100%?
Or, charge along the way for 10 minutes and drive as fast as you want without needing to do something utterly stupid like “drafting” a semi going 80mph.you can improve your range by drafting behind other vehicles. Especially if you can get behind a box truck, van, semi. Then you can go 80 and the penalty is similar to driving 60.
You should review the consumption graph of your trip. (Like this graph from this thread)My buddy got a 2018 long range AWD 22k miles from Tesla last week.
he finally charged to 100% and only got 281 and we left to Vegas from SoCal
and only went 200 miles before we were under 18 miles left.
Aero wheels and highway speed was about 78-80.
- Does 78mph really kill the range that fast?
Vegas is 241 from my house so we thought we would make it all the way there.
I believe the mile spec is for 65 MPH and seems accurate to me at that speed. The best range is at 38 MPH, IIRC, and at that speed, expect better than 400 miles of range,does 78mph really kill the range that fast? Vegas is 241 from my house so we thought we would make it all the way there.
But that may change the estimated range, not the reporting of the nominal capacity right?
No one said tailgate. You draft behind other vehicles all the time.
There's a huge difference between being head of the line or being behind other vehicles. Try it sometime instead of mouthing off.
...However, to get any noticeable reduction in energy expenditure, you would have to follow at an unsafe distance for a human driver’s reaction time. To gain any benefits in fuel economy, you would be putting yourself in danger of a collision if the truck came to a sudden stop.
What terrible advice by ABRP on the route out to Vegas, you want to arrive at a Supercharger with a much lower state of charge to improve charge rate. Go to Baker, top up for 15 min then on to Vegas.A more realistic situation would be to use a speed limit of 78 miles per hour as you mentioned,
and I found the following trips information:
You can noticed that the total trip duration are very similar between
- lowering the speed to avoid superchargers, and
- driving faster but making quick stops at a supercharger.
