Do we have such degradation graph according to SoC for LFP batteries?Exact how do the car tell you that low SOC is bad for the lithium battery?
I would say that you have seen information in your car from that you have drawn your own conclusions( that might not be right).
If you read the manual it clearly states that the 12V battery might get damaged if the SOC gets so low that the lithium battery stops charging the 12V battery. ( 12V lead batteries is sensitive to low SOC, and sulfates if discharged.)
There is no warning at all in my Tesla manual to leave the car at low SOC, except that not leave it so the battery goes below 0% SOC. A rule of thumb of 1% per day is used to help cslculate the loss during longer time.
Tesla says ”Below 90%” in the manual. They do not sat ”90%” or ”80”.
You might wanna look at what advice Tesla avtually gives.
Tesla of course give us a as big window of usage as they can, to make the life easy, and at the same time not cause too much degradation. The 90% daily rule doubles the battery life, so thats a good reason.
There is no information in the manual that states or implies that low SOC is bad for the lithium battery. There also no such info in the car. The low power at low SOC comes from the reason that lower voltage gives lower power (P= U x I ), and that the internal resistance increases at low SOC icreases a lot ( again, P= U x I).
There really is no way for Tesla to use the NCA Battery technology and get around the law of physics that applies to the NCA technology as we know it today. In many of the research reports the cells tested was panasonic NCR cells, very close to Tesla cells and in some cases more or less panasonic Tesla cells.
You are of course entitled to your own approach to your charging habits.
How would that compare with the batteries found in LR and Performance models?
