@AAKEE
As we head into hot summers in Australia - often temperatures are 30-40⁰C during the day and 20⁰C night. I wonder if I should reduce max SoC or changing the charging session time. I am now able to charge at one workplace for free with 2.3kW AC
When it comes to free charging and the opportunity to charge for free and to balance the saved money to the possibly increased or reduced degradation, I am not the guy to ask. I have a fixed electrical rate, quite cheap so I do not think anything about that. I have free supercharging but I still charge full before leaving home for a longer trip, even if supercharging would save me a few buck. Just for convinience, not to save the battery either.
This was my routine during autumn when the max temps were 20⁰C and down to 10⁰C overnight (average):
My garage is not insulated and has some delay in temperature equalisation between inside and outside
Tuesday SoC 40% charge to 70% (free workplace charge)
Wednesday SoC drops by 10% (not at free charging workplace)
Thursday SoC drops by 10% (not at free charging workplace)
Friday SoC drops by 10% (not at free charging workplace)
Saturday SoC 40% charge to 50% (at home during day - charge at home with solar)
Sunday SoC 40% charge to 50% (free workplace charge)
Monday SoC 40% charge to 50% (free workplace charge)
Would you do any different?
Hard to tell.
First the basics, if you like to reduce the degradation (otherwise you would not ask, I guess):
-Do not charge more then needed until the next charge.
-Charge often, it reduces the cycles size which is good, also reduces the need on the point above.
-Charge late, to reduce the average SOC, this will be extra effective when you need to charge above 55% (as above 55% increases the calendar aging).
You have 40% as the low point, and do not need a 40% reserve range? I would try to only charge to 55% on tuesday. Would put you at 15% end of the friday before the saturday solar charge. 50-40 or 30% has about the same calendar aging, and the batterty is actually also happier below that, so the only thing to look out of in terms of low SOC is your range anxiety (and to nod be stranded somewhere).
What do you consider is "high" ambient temperature?
Anything above freezing
No, but there is not really a sharp limit. And you mostly can not do anything about it. The warmer it gets the higher the calendar aging, but in a smooth increase with increasing temperature. So no limit.
With SOC it is different. SOC at or below 55% (for Panasonic NCA, I do not know I you did get the LG cells yet, in that case 55% is 60% instead).
You can se for a specific SOC that the calendar aging is progressively higher due to temperature, but no specific limit.
For different SOC's you can see that 55% "costs" about 2.75-3% at 25C temp for the first 10 months and that 70-100% will "cost" about the double amount.
That curve is generalized by only one test point at 55 and one at 60% but no point between. The research did find the exact point that is about 57% SOC, to stay below. Due to the buffer 55% displayed is 57% true SOC so we can use 55% or below.
