Where’s do I find thisAlso FYI, if you need to adjust the horizontal aim of the headlights (it was wildly off on my Plaid from the factory), you can do so by entering the adjust headlight menu while in service mode.
It’s the same adjust headlight menu as as usual, you just need to open it while the car is in service mode. You can then control horizontal aim with the scroll wheels (pushing left and right)Where’s do I find this
I see this in the service section when parked. So in service mode there’s another one for left and right ?It’s the same adjust headlight menu as as usual, you just need to open it while the car is in service mode. You can then control horizontal aim with the scroll wheels (pushing left and right)
You mean this ? So your saying I can adjust each light left/right ?It's the same menu. But if you're not in service mode, horizontal aiming doesn't work. You would push the scroll wheel to the left and right (the diagram shows it, but on US cars it doesn't work outside of service mode)
Wow that was quick
Huge difference. I now have 4 projector lights which is brighter. I’m have a 2023 mxp (no -matrix) and my co-worker got a 2924 w/matrix. I test drove his car and noticed the light improvement at night. But currently, the matrix lights loose the slow speed head light beam with turn signals. I assume the matrix will get that back once adaptive lighting is enabled.Wow that was quick
Is the light output noticeable better? Worth it?
Parts required assuming the Model X has ethernet port are:
- Lights themselves
- 6 pin to 3 pin adaptor
Is that it? and then laptop/developer to reconfig?
I just checked under the yoke and I have this plug. Is this H-MTD?Huge difference. I now have 4 projector lights which is brighter. I’m have a 2023 mxp (no -matrix) and my co-worker got a 2924 w/matrix. I test drove his car and noticed the light improvement at night. But currently, the matrix lights loose the slow speed head light beam with turn signals. I assume the matrix will get that back once adaptive lighting is enabled.
Look above the phone charger . It’s either Ethernet or H-MTD. My S has thisI just checked under the yoke and I have this plug. Is this H-MTD?
Ohhh didn't even know such place existed. Does that part just pull off if I wedge something in?
Yes stick a plastic pry bar to the top of itOhhh didn't even know such place existed. Does that part just pull off if I wedge something in?
