Revision F Battery Pack?
Discussion in 'Model S: Battery & Charging' started by mesalum, Dec 13, 2014.
  1. mesalum
    mesalum Member
    Wilton, CA
    I took the Factory tour yesterday. While we were at the Chasis 1 line there was a stack of battery packs. There was a 8x10 sheet of paper attached to the stack that was labeled "Rev F."
    When I got home I verified my new P85 has the Rev E pack.
  2. Hodginator
    Hodginator Member
    Virginia
    It would be interesting to know what has changed with each pack revision.
  3. AmpedRealtor
    AmpedRealtor Well-Known Member
    Buckeye, AZ
    Six battery revs in only two years... wow!
  4. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    It certainly would, but unlikely we will ever know. Probably only J.B. and the Tesla powertrain design engineers know all the details about the differences.
  5. wk057
    wk057 Senior Tinkerer
    Hickory, NC, USA
    Probably a ton of subtle differences, although likely nothing major.
    On the B and A packs I have seen photos of dismantled, the BMS boards on the modules were hard wired to each set of cells, where on the D-packs they have plug in connectors on the BMS boards.
  6. Cottonwood
    Colorado
    There is an unverified theory that the "F" packs support higher discharge current for the higher power P85D.
  7. darthy001
    darthy001 Love my car, hope Tesla can get as great!
    Bærum, Norway
    Someone should point MarcG in the direction of this thread. With his brand new P85D he could at least keep that theory alive, or kill instantly if he has the E-pack.
    Btw, where is this "theory" coming from?
  8. jerry33
    Texas
    The hypothesis is likely due to the additional current the P85D requires for two motors when using insane mode.
  9. darthy001
    Bærum, Norway
    Yes so I assumed as well, but was more thinking if there was some more substantial background info that this was based on. Other than the 480KW-screenshots of the speedo.
    ah well, I guess we will soon know if MarcG or others with a fresh P85D has the E or F.
  10. apacheguy
    apacheguy S Sig #255
    So Cal
    I thought that's where the E packs came in. They are also a very new release.
  11. stopcrazypp
    stopcrazypp Well-Known Member
    I was also under the impression that the E packs were also a new release. So it's surprising they had another revision so soon.
  12. jerry33
    Texas
    The C pack didn't last long. I've never heard of anyone actually getting one.
  13. islandbayy
    islandbayy Active Member
    Greendale, Wisconsin
    And here I thought they just made that aftermarket Hamster Wheel in the frunk a official feature :(
  14. A.G.
    A.G. Member
    Chicago
    Have you gotten your car back? Would really love to see what Tesla did for you since you are essentially their biggest brand ambassador (Of course with Bjørn)!!!
  15. MarcG
    MarcG Active Member
    San Francisco
    Sorry guys, I've had this on my to-do list of things to check. Just took a picture of it and I'm afraid the theory dies here:
  16. randompersonx
    randompersonx Member
    Miami, FL
    Interesting though, it shows "DUAL MTR" on the top of the sticker, implying that something did actually change on the battery for the D.
    If you check this previous posted picture:
    http://www.teslamotorsclub.com/attachment.php?attachmentid=64607&d=1417069840
    The part number is different ,too.
  17. pgiralt
    pgiralt Supporting Member
    Cary, NC
    Perhaps there are an extra set of HV connectors that go to the front motor?
  18. MarcG
    MarcG Active Member
    San Francisco
    Very good guess, I would bet that's why there's a D-specific pack.
  19. islandbayy
    Just a thought, unless the new packs are backwards compatible with the old cars as well, might throw a wrench in the works or at least require multiple variations in packs at the swap stations.
  20. apacheguy
    So Cal
    Everything up to a D is backwards compatible with B and A. Anything beyond that is anyone's guess as we've never seen a pack swap to an E or F pack.
