That is one of the strangest ways to show options and their on/off values that I've seen. Why not follow what other systems use as they have many years of experience and user control group feedback *showing* what works and what doesn't for the mainstream. JMO.I'm using the 2.0.5 on Android.
The new settings page is very confusing. The two choices are solid grey or solid purple without any obvious way to tell if purple means the value on the left or the value on the right.
<Switch Grid.Column="1"
HorizontalOptions="Center"
IsToggled="{Binding Value.Setting}" />
I am using Microsoft Xamarin.Forms for UI. This is the code
Code:<Switch Grid.Column="1" HorizontalOptions="Center" IsToggled="{Binding Value.Setting}" />
Not sure how I can change that. Looks like they have an open bug on it; Rendering Issue with Xamarin Forms Switch component on Android only · Issue #10415 · xamarin/Xamarin.Forms
Odd range numbers. I think the app is confused. SoC goes way beyond 100 sometimes.
The switch to turn off the front motor doesn't seem to work.
I guess the new display is for beta users? I think I will stick with the current version for a while...
Thanks for all the feedback! It led to a speedy fix of the new firmware changes:
V2.0.5 is out/pending review in both Google Play beta program and Apple TestFlight. Feedback on the Model S/X changes will be greatly appreciated!
Still nothing on TestFlight
