mcirish
Can you confirm that for a 2022 Model S, if I want SMT to work using an ODBLink LX then I will need to connect wires from pins 9 and 10 on the blue diagnostics connector over to pins 6 and 14 on the OBD2 connector?It appears that the Vehicle bus is on pins 9 and 10 on the Tesla connector, with pin 9 being CAN high and 10 being low. Those need to be wired to pins 6 and 14 to use most accessories that work with the various apps. I moved the pins around and can confirm I'm getting useful data from Tes*lax
Edit: I'm using the signal profile for 2021 Model 3/Y in the app.
Earlier there was a "upon further review" statement that said to use pins 13 and 14. Which should I use?
Please advise, thanks.
