Shocked by the new Roadster rolling out of the Tesla Semi!
Cloxxki
1,362
147
Rotterdam
Hi, the only spec I found for Powerpack is the 50 kW AC output from Tesla Powerpack do you have another source for its charge rate?
It's an automotive term also. You use high (dis)charge rated cells. Think, 10x faster charger than Tesla cells. And much less prone to heating under high load. Many hybrid cars have tiny little packs that put out enough power to drive decently.
A 200kWh pack to fit such a sleek car is not possible with today's tech. Many have been promising 3-fold energy density, this would be the first one to make it to a prototype of this scale if true. But if true...why a 3 year wait? Car seems to work.
animorph
2,130
1,521
Scottsdale, AZ
Hopefully they have cooling enough to allow sustained track performance.
This is insane, and obviously all made possible by this mysterious 200kwh battery place.
Any estimates on battery specs? Also, how many kwh will the semi have? 1,000 kwh? 80% in 30 minutes?!?!?!
Who cares about the roadster and semi... tell me about the batteries!
No reason the batteries couldn't be those we are using today. One of the individual battery cells will charge 80% in 30 minutes. Hook a bunch of them all up at the same time and they can all charge 80% in 30 minutes. The only difference is how many cells you are charging, which only affects the required charging power. Model X/S, new Roadster, or Semi.
It kind of appears that they have something like two Model 3 battery packs stacked one on top of the other (the car was reportedly only a little smaller than the M3 and with a higher seating position), plus maybe an extra 2/3 pack worth stuffed into the frunk and trunk areas. No obvious frunk or trunk gaps that I could see on the prototype. Maybe they're full of batteries and motors?
mongo
12,866
37,855
Michigan
Ah! power pack, not Powerpack. Sort of like a super capacitor module? Seems it would be hard to hide the recharging that would be need at such an event.
Cloxxki
1,362
147
Rotterdam
Such a 0-70 run and back doesn't take a lot of energy. A large pack from power cells (really, it's Tesla that's using cheap slow cells, there is a whole world of 5-10x faster cells out there) could be (a couple) dozen kWh and suffice to demonstrate the function of motors and tires.
If Tesla actually already has a 200kWh pack that fits a Roadster, the 0-60 performance shown in testrides is not the big news.
Reactions: scaesare
KarenRei
ᴉǝɹuǝɹɐʞ
Jul 18, 2017
9,619
103,828
Iceland
I guess I don't see this car as any dirtier to build than any other similarly-sized car (e.g. the Model 3). It has more battery cells, yes, but they should last that much longer before range becomes a killer issue, and are presumably still recyclable as other lithium cells are.
This is a really interesting point you make. Because the recycling rate on the metals in the cathodes at least should be nearly 100%. Nobody is going to throw away hundreds of kilograms of what's effectively super-high-grade nickel-cobalt ore, and nor is there a reason that any meaningful percentage of it should get lost in the recycling process. Nickel and cobalt demand are only going to continue to grow over time, so when the metals from your battery go back onto the market, they displace what otherwise would have had to be mined at that point in time.
In short, by "consuming more" by buying a vehicle with a larger battery, you're not actually causing more mining overall. You're just making it happen sooner. More mining now, but reducing nearly the same amount of mining later.
ecarfan
19,186
13,841
San Mateo, CA
The latest one is called Roadster 3.0 . How will this new 2020 Roadster be called?
Either just “Roadster” or it won’t have any name badge on it at all, just like the Model 3.
Yeah, but the original Tesla Motors concept was to start at the top of the market and work their way down. This is not working its way down. They could have produced the electric counterpart of a Corvette instead of a Lambo. Yes, I know that bragging rights are a thing. . . and that Elon Musk does, in fact, have an ego to feed. Practically speaking, though, this does mean that many of us are ultimately going to look toward some other car maker for our next electric sports car.
I believe I understand your point, however I think Elon feels that this new Roadster is an effective way to show the world of automotive enthusiasts that any attachment they may still have to noisy ICE supercars is deeply irrational. The new Roadster outperforms them for a fraction of the price.
I would not rule out a lower priced version of the new Roadster at some point, with half the range (most people don’t need 620 miles of range) and less power.
Curious about the statement by ELON, you can drive one of these with your regular driver license. Typical commercial license not needed? no airbrakes... no 18 gears to shift... just massive size...
Elon was referring to the Tesla Semi truck when he made that comment.
The negativity is from being wasteful. I expect to see Tesla criticized for this. How can you have a mission of changing the world and fighting climate change, etc etc
and then turn around and spend all of this time, energy, and by the way a carbon footprint, to produce a car that is just a plaything for a rich guy?
Producing a thousand or so of the new Roadsters every year while simultanteously producing a half million Model 3s should even the scales.
JRP3
Hyperactive Member
Aug 20, 2007
19,451
42,624
Central New York
The idea that this new Roadster is somehow "wasteful" is beyond ridiculous. It's a smaller car than the Model 3 and more aerodynamic than an "economy" car like the Bolt. That means it's a more efficient vehicle, i.e. less wasteful. 99% of the time these Roadsters will be driven at normal speeds on normal roads and will return amazing wh/mi figures.
bolosky
697
589
Just to revive a thread I started 8 years ago (!), I did a very back-of-the-envelope comparison of the (obviously original) Roadster to a bicycle in terms of marginal carbon footprint, comparing the electricity used to power the Roadster to the food used to power a bike. The answer was that they were actually pretty comparable (with lots of caveats pointed out by me and others on the thread).
If you believe 620 miles on 200kWh, then the new Roadster will be less efficient (323 Wh/mile), but still will be tons better than most gasoline cars. So, calling this out for not being green is kind of silly.
Bike vs. Roadster
bolosky
697
589
I think the actual range will be better than that and highway efficiency will be better than the original Roadster. The aerodynamics almost guarantees it.
You'd think. I was a little surprised. IIRC, an ideal mile in the original Roadster is 238 Wh. In practice, as we all know, it's really hard to get that, but to get as bad as 323 you either have to drive really aggressively, it has to be really cold, or there has to be a lot of rain.
The new Roadster will clearly be a lot heaver than the old one, though. It's much bigger and has a bigger battery, too. How much that offsets the better aerodynamics is hard to say (and in any case it depends on driving profile).
calif94577
82
77
Ventura, CA
With a 200kwh battery and 7k+ lbs of torque on demand, I don't think anyone driving this will give a living crap about efficiency lol. Put me behind the wheel of one of these and watch me do 250+ from LA to SF and not blink an eye... Ill gladly stop halfway to supercharge. Cops still wouldn't catch up with that stop LMAO :D
oktane
1,558
1,531
Another point is, Tesla may limit roadster performance after the fact like they did on the P100. Used to get full performance WOT, and Tesla changed it so full performance only in launch mode. This was a compromise after much public uproar.
Reactions: gowthamn
WannabeOwner
5,758
2,893
Suffolk, UK
I'm talking about the aluminum production, steel production, etc. everything that goes into manufacturing this car.
Does your carbon footprint stand scrutiny?
The secret they’re not disclosing is that the performance numbers are not sustained.
They may not have been sustaining the headline figure, but the joyriders certainly seemed impressed! and the audience putting down $50K deposit is presumably already familiar with, and comparing against, Ludicrous launch and the cars were launching "all night long", for me its hard not to draw the conclusion that it was "sustained"
A powerpack can charge at a very high rate
There was nothing implied that they recharged during the night. Sure, they may well have done, but Tesla is going to look pretty stupid if that comes to light and the employees / drivers were lying on camera about it. I'm happy to believe that they were "launching all night" and that that was on a single charge.
Reactions: Jaff
Electroman
6,116
6,173
TX
It is clear that nobody here has an idea how they could accommodate 200 kWh in such a small space and how much it will weigh, unless the cells have a magic chemistry.
If it is too good to be true, then most likely it is.
Rowan256
1,018
505
Amsterdam
Then still, even if it had to recharge like 5 hours instead of 0,5 , it's still absolutely amazing
Maximilien
753
615
Irvine, CA
My guess is that when other ICE companies worked their asses off to catch up 2.0 second 0-60 by 2020, Tesla will ruin it with a surprise by announcing 0-60mph in 1.6 seconds!!
Looks like Tesla enjoys trolling other companies.;)
GG ICE...
