Thanks Kevin for excellent instructions on how to use my adapter with a UK/European Type 2 cable and charging station.
Most manufacturers of charging stations recommend that you stop charging at the charging station. There is usually a button to press or swipe your card, etc. It's just as good if you "stop" from the VDS or with a smart phone app such as the Tattler or OVMS. In any case you won't damage the Roadster if you pull the J1772 connector before you stop, but it's not recommended.
These are the instructions I usually give people (in the US/Japan):
1) Insert the adapter into your Roadster first before engaging the J1772 connector.
2) Always stop charging before unplugging the J1772 connector. You can stop charging from the VDS in your Roadster or from the J1772 charging station.
3) Never attempt to remove the adapter without first stopping charging and unplugging the J1772 connector from the adapter.
@Alexander, It's great to hear your adapter arrived and you're able to use it! I hadn't heard anything and was about to send you a message. If anyone is interested, I have 70A Type 2 cables available if/when there are locations with that capacity in the UK.
