MX100D MCU2.5 2018.32.2
Sorry, but the thread got bloated, so I skipped to the end.
Can anyone confirm EAS auto deactivation when signaling a lane change, and lack of parallel lane recognition (left or right) even though forward looking traffic recognition still active?
Thanks, shadowndust. I should have thought to try that first.My auto lane switching was deactivated upon updating, but going into the settings and turning it back on was fine.
It took me a few days to remember to check that myself. At first I thought it was broken too.Thanks, shadowndust. I should have thought to try that first.
I will never allow service to install a software update ever again. Everything was pretty much working fine before the update that caused my IC to reboot (28.X). Now on 2018.32 the IC reboots and the browser doesn't work. Gee, Tesla, can you please ruin my car even more?Are you on this release? 32.2 and it's still happening? Damn.
I've been on 2018.32.2 for a little over a week, coming from 2018.26.2. No IC crashes so far, with or without Nav. I'm glad to see that traffic information is current on the CID, and the updating seems a little smoother. AP1 works about the same as it did before (very well, within known limitations).
Bruce.
Bruce.
Got the update to this version last night.
I did notice that my traffic is refreshing more frequently now. Still a bit of a delay after starting up the car, but I don't have to manually refresh it or use the navigation just to get traffic updates.
I've encountered a really crummy bug though:
When listening to Slacker Streaming, if I use the steering wheel "forward" (or backward) button - it doesn't work switch streaming stations.
I can switch streaming radio channels on the media player screen, but I cannot use the steering wheel.
Even worse, if i try to switch stream channels on the wheel buttons - it seems to make my media player freeze after 2 or 3 attempts.
I've repro'd this 3-4 times on the way home from work today & each time I have to reboot the infotainment system.
Once it's frozen, it'll finish the existing song but it will not respond, even to screen inputs. You cannot change stream, cannot skip song, cannot switch to radio, either via steering wheel shortcuts or via the media player on screen.
If anyone else could see if this is happening to them, would appreciate it
I have with this 32.2 update the same behaviour, except with FM radio. I don't have Slacker, but Spotify (which works ok as usual).
So, the odd behaviour you describe is exactly what I have with FM stations. Anyone else?
Came here looking if anyone else had this. I got this on the Model X with the update.
If I touch the steering wheel buttons, the MCU media player sort of partially freezes. Changing FM radio stations stops working (you can still hear the station you are listening to but nothing will change the station) and also operating Spotify (here in Europe) stops working (goes into a waiting loop on the screen). Resetting the IC does not seem to have any effect on this, the buttons are broken. Resetting the MCU helps on the MCU side, though.
I've reset the MCU and IC several times and the way it seems to me is that the steering wheel buttons freeze the media player on the MCU side for whatever reason. If I reboot just the MCU and not touch the steering wheel media forward/backward buttons, FM radio and Spotify work just fine through the touchscreen, which is how I've now been operating the media player. Not optimal...
Back in the earlier days I had an odd (but protracted) issue regarding the steering wheel buttons - Instrument cluster (steering wheel) forgetting radio favorites? - but I've not had any such problems since that got fixed, until now.
From yours and the other previous report, what is odd is that the consequence (Media player freezes) and the cause (using skip buttons) are similar but in different context.
In my case only in FM. In Spotify or TuneIn, I can use them fine.
New update is running this morning, I’ll update here if it solved it for me or not.
@AnxietyRanger I have the same on 28.5, another person reported it on 34.x. It's discussed in 28.5 thread, but no useful outcome.
Got this update yesterday morning and ever since the long press on the left steering wheel buttons to change Slacker stations don’t work. Anyone else experiencing this?
Yes, I have the same problem except that a reboot let me use the buttons on the screen until such time as I pressed any of the LH buttons on the steering wheel; as soon as I did that, the screen buttons died. My SC has been working on the problem; the engineer says he thinks the buttons need replacing but I think the coincidence with the new firmware indicates strongly that it's not a hardware problem. I will update as and when.
Not so; I have 32.4 and the audio problem introduced by 28.5 is still there.
