newbie here although I’ve had solar for maybe 10 years its a ‘free’ system where we get to use spare electricity but the installers get the exports. In theory I think that means we should try and use a battery to leverage the output as much as possible but its only a tiny array - 2.9kw I think so probably not a lot of excess especially now I’m wfh fulltime?
Is the general aim (balanced vs cost) to try and use battery to store excess and then feed back into the house to fill out the gaps early/late when the solar dips below house load? And top up with off peak if needed? I’ve seen solar calculators but is there somethign that can also then estimate your house load (eg if you have octopus half hourly readings), and estimate a battery or other options to smooth things out?
Yes, exactly that.
Our Solar Array can be producing 5kW of power constantly for some time during Summer.
That's a lot of power, and you can't always use it all immediately.
So having a lot of battery storage, allows you to store that excess power to use when the Sun goes down. Continuing through the evening.
Another way of doing it without battery storage, is an export tariff that equals your import tariff. So if you can sell your power at 5p and buy it at 5p... then you're using the Grid as your storage battery.
The two main things with storage batteries is
1) kW capability. How much power can your battery deliver at maximum demand.
If the battery can only deliver 5kW maximum at any one time... anything over this has to be got from somewhere else (solar generation or Grid). So understand what your homes maximum demand might be, as an example...
Showers : 8kW
Heat Pumps : 2.5kW
Induction Hobs : 2kW
Hair Dryers : 2.5kW
2) kWh Capacity. This is how much Energy can be stored in your battery. The more energy you can store, the longer you'll be able to run power off it.
Storage capacity can be used for downloading cheap rate electric overnight. Ideal in Winter when Solar Panels are quiet. We buy our electric at 5p per 1kWh and can store 27kWh overnight. This gives us a days worth of cheap power during Winter, topped up by a small amount of solar power.
In Summer, the storage is filled with Solar Power, so we become completely self-powered from April...
