I was quoted 2 powerwalls & gateway recently for £16.5k including install as option for taking advantage of off peak rates4 x 375W LG Black Panels (to get 5% VAT) plus 2 PW and a Gateway £19.8k
Are you battery only or is this adding to an existing PV setup?Take a peek at Pylontech batteries. US3000C, Approx £1k for 3.5kWh plus inverter fitting and cabinet. I just bought 5, 17.5kWh approx 16.5kWh useable. And a cabinet for £5300. I ready had a Victron inverter. (Approx £1500)
The Pylontechs are modular avd you can add up to 8 in each stack.
Combine this with Go (or Go faster ) I'm running the house on 5.4 to 6.9p/kWh
Hope this helps.
I have 5.6kWh sse facing and 1.2kWh nnw facing. The 5.6 are limited to 4kw output.. no DNO approval, Also a 9kwh heatpump providing heating and hot water in the winter.. solar thermal in the summer.. batteries will save a good bit in the electricity bill.. but everybody is different and so needs to make the calculation for themsves. Mine on the current Go prices will payback within 6 years and reduce electricity bills from expected £1400 to somewhere about £300.. but that will take time to prove.Are you battery only or is this adding to an existing PV setup?
I don’t think that’s far off, take a look back at #511, my quote.I've had my first quote back, but I don't have any perspective how good a quote it is. Opinions on the following?
19x 390W Trina Solar = 7.41kW
1x Powerwall 2
£19300
This is where I bought mine.. couldn't find them cheaper.. lots of youtube videos on them.. simple to add batteries.
Pylontech US2000C, US3000C & US5000 Battery Storage available at Trade Prices – ITS Technologies
Pylontech's latest US2000C, US3000C & US5000 with 95% DOD suitable for solar & wind battery back up available from ITS Technologies. Nationwide delivery.www.itstechnologies.shop
They've only got the 2.4kWh batteries on the website the 3.5's take up less room, and the 3.5's are slightly better value for money.Pylontech Battery | Solar Pylontech Batteries | TradeSparky
Pylontech battery, in-stock, next-day delivery from TradeSparky. Leading supplier of Solar and electrical renewable goods and accessories.www.tradesparky.com
for the sake of less than £20 i'd rather not put all the eggs in one basket, should a unit fail in the future.......They've only got the 2.4kWh batteries on the website the 3.5's take up less room, and the 3.5's are slightly better value for money.
£312/kWh for the 2.4 and £296/kWh for the 3.5. Something else to consider.
Hi, just wondering if you are willing to share the quoted price, I've increased my requirements to 4.8kW with a similar set up ( apart from being 16.4kW battery).I just ordered 4.8kw solar system givenergy hybrid inverter and 8.2kw battery. Our fuse box is being replaced, there is a lot of scaffolding and I'm having a few other things added, its not cheap in comparison to the quotes being banded about here. Prices are definitely going up.
Ok no problems -as long as you're happy with it that's all that matters.Im not sure its worth it, there is a couple of k of additional work going on at the same time.
(also slightly embarrassed that I am potentially overpaying a little)
You probably had 20% VAT applied; only 5% for me.I was quoted 2 powerwalls & gateway recently for £16.5k including install as option for taking advantage of off peak rates
I noted the 100A meters were almost twice the price of the identical item on Amazon UK.Pylontech Battery | Solar Pylontech Batteries | TradeSparky
swings and roundabouts, don't buy everything from the same placeI noted the 100A meters were almost twice the price of the identical item on Amazon UK.
